Results 1 to 10 of 13
Thread: suspension URGENT
    Regular Member fiend61's Avatar
    Nov 2011
    york
    Vehicle : vectra 2.8 turbo
    Trim : elite
    Engine : 2.8 turbo
    Default suspension URGENT
    hi
    i drive a vectra-c 3.2 elite 03 plate, two things really has this model got sports suspension ? and i have just bought some kyb coilsprings all round but the shape of them are different to the ones that are on, the new ones have one end of the coils closer together than the other end so which way up do they go closer coils to the top or bottom ????
    tia
    Glasgow
    No you dont have sport suspension.
    Sri, Design and GSi had sport suspension off the top of my head.
    Regular Member vxpenfold's Avatar
    Nov 2010
    sittingbourne,kent
    Vehicle : Vectra Hatchback
    Trim : Life(well it was)
    Mileage : 166000
    an elite will have higher than standard suspension
    Nov 2011
    york
    Trim : elite
    Engine : 2.8 turbo
    ok then no sports suspension, what about the coil springs are they tighter coils to the top or bottom and is it different from front to rear ? fitting them now this is why i need the info
    tia
    Nov 2010
    sittingbourne,kent
    Mileage : 166000
    normally the spring will be slightly smaller on end(where the coils finish) and you should check on your old ones as to which end goes where or they wont fit in the spring seats properly, but normally the tighter coilers are at the top and there should be a very noticeable difference between front and rear springs, rears being shorter
    South east
    The coils being closer together on one part of the spring means they're "progressive" springs, i.e. the spring-rate differs across the spring; this is part of the design and intentional. By the way, fit the tightly-coiled part at the top, to protect against stones getting trapped between the tight coils.
    Vehicle : Jaguar S-Type V6
    Trim : Sport
    Engine : Petrol
    If your dropping your elite by changing springs. You may need to change your elite shocks at the same time!
    I could be wrong though. ????
    Nov 2011
    york
    Trim : elite
    Engine : 2.8 turbo
    Quote Originally Posted by DTI-Steve View Post
    no not lowering standard length springs
    Regular Member phil67's Avatar
    Nottinghamshire
    Vehicle : Vauxhall
    Trim : Exclusive
    Engine : 1.8
    Have you got any spring clamps as there is a lot of pressure under those nuts
    Full Member
    Jan 2008
    N/A
    74 Post(s)
    Vehicle : N/A
    Trim : N/A
    Engine : N/A
    Year : N/A
    you already posted this on vvoc and got answers from the guy on there lol
  1. Suspension knocking? Will Vec c suspension fit a Siggy?
    By shane5861 in forum Handling & Braking
    Last Post: 6th May 2011, 14:20
  2. DTi suspension v CDTi suspension
    By jamesy in forum Vectra C / Signum Car Chat
    Last Post: 3rd March 2011, 19:02
  3. Urgent help with 2.0t .....I'm under it now
    By ROCKATANSKY in forum Vectra C / Signum Car Chat
    Last Post: 30th January 2011, 18:28
  4. Replies: 5
    Last Post: 21st March 2010, 12:34
  5. Urgent or not so urgent ?? Service Warning Light
    By martinh67 in forum Electrical & ICE (including SatNav)
    Last Post: 26th July 2007, 09:54
