Results 1 to 10 of 18
Thread: LED sidelight bulbs/What do you use?
    Regular Member lew1984's Avatar
    Jul 2011
    Cheshire
    Default LED sidelight bulbs/What do you use?
    Hey guys,
    I've recently acquired a set of Canbis error free LEDs, fitted them the other night. I realise they strobe which is no problem but when the engine was running and the sidelights on, I noticed the drivers side was strobing. (Shortly later I took them out)
    Is this normal, does it eventually stop when the engine has run for a certain amount of time?
    What does everyone else use for their sidelight bulbs? I'm pretty fed up of the dull yellow look.
    Cheers,
    Lew
    Engine : 1.9 CDTi
    Mtec 501 bulbs.
    Look blue untill they are on but then give a nice white light (Just not very bright)
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    I left the LED sidies in... the strobing is just the lamp check - a tiny pulse of power that isn't enough to light an incandescent lamp but will light an LED - and in daylight barely noticeable.
    My GSi has now passed 2 MoT tests with the LED sidies fitted and even with me pointing the pulsing out to the tester. From a safety point of view the LEDs are brighter, clearer and whiter.... from a power point of view they draw a fraction of the power of normal lamps.
    On a side note when parking in darkness I've even had a few locals say they thought it was part of some super-dooper alarm system - I'm not about to correct them.
    Feb 2012
    Southampton
    I took mine out coz of the strobing. Does it stop after a while. I thought the car was throwing a wobbly
    Jul 2011
    Cheshire
    Quote Originally Posted by Handyandy-UK View Post
    Do they strobe simultaneously or was they flashing alternatively?
    Again with them being on, I noticed the drivers one was pulsing also... just to clarify this is a lamp check and this will stop eventually I take it?
    Regular Member dcm23251981's Avatar
    Jul 2011
    burnley
    mine strobe they go out after a few min of ignition being off but was told if you fit a resistor to them it draws all the power and stops it but never tried it
    Jul 2011
    Cheshire
    Quote Originally Posted by dcm23251981 View Post
    Interesting. Do you know how this can be done?
    Jul 2011
    burnley
    fitting the resistor to the plug or pulling the wire back and soldering it to them
    Jul 2011
    Cheshire
    Any ideas which resistor I need to do this? Might give it a bash.
    Lew
    Jul 2011
    burnley
    1 watt resistor from maplins
    here is a link but its for a 3 watt which will do
    http://www.maplin.co.uk/3-watt-wirew...=2173&t=module
  1. sidelight bulbs
    By tiimi in forum Vectra C / Signum Car Chat
    Last Post: 26th December 2012, 18:26
  2. M -Tec 501 Sidelight Bulbs
    By tony-1977 in forum Vectra C / Signum Car Chat
    Last Post: 6th June 2012, 20:50
  3. Sidelight Bulbs
    By Tam80 in forum General Motoring Chat
    Last Post: 26th May 2012, 21:51
  4. 501 sidelight bulbs
    By VectraElite 2.2DTi in forum Electrical & ICE (including SatNav)
    Last Post: 10th December 2010, 23:21
  5. M-tec 501 sidelight bulbs x2
    By bobby-tupper in forum Parts for sale
    Last Post: 31st May 2010, 14:24
