Results 1 to 10 of 22
Thread: another problem!
    Regular Member Turbomanrony's Avatar
    Sep 2010
    LEEDS
    Default another problem!
    my vectra cdti sri 150 wont start
    turns over and fires with easy start
    i have changed the fuel rail
    all 4 injectors
    fuel pump
    i dont know what else to do its puzzling me
    has any 1 had a simlair problem?
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Does it run after you have started it using easy start?
    BTW, once you start using easy start you will continue to have to use it. The detonation of the ether eventually damages the piston rings and it will not start without it.
    Have you checked the glow plugs are working properly? When did the problems start? What we the symptoms the very first time, and prior to the first time it wouldn't start? Any prolonged cranking? What happens if you just crank for a long time, and white smelly smoke from the tailpipe?
    Why did you change the pump, rail and injectors?
    Sep 2010
    LEEDS
    no it will only run on easy start, i dont think its geting any fuel so that why i changed the rail and injectors plus pump.
    i bought it like that basicly as a non runner but cant seem to get it to run
    Quote Originally Posted by Ste View Post
    Admin plasma's Avatar
    On the Forum
    247 Post(s)
    Engine : 150
    Mileage : 74000
    check fuel rail pressure (with a diagnostic device and not manually), if its not building enough pressure it wont let the injectors fire up
    Not sure how your managing to get it to start on easy start, where are you spraying it into? the air intake?
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
    Sep 2010
    LEEDS
    im sprayin it in the inlet, if i keep it sprayin it will run untill i stop.
    i hav had it on a machine and it picks up pressure
    Sep 2010
    LEEDS
    bump
    wirral
    33 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Start with the basics
    Are you getting low pressure fuel?
    Do you have diagnostics to read rail pressure?
    Last edited by Critch; 12th February 2012 at 18:23. Reason: Sausage fingers and iPads don't mix
    Sep 2010
    LEEDS
    yes a snap on computer its at the right pressure, i dont think the injectors are injecting fuel in.
    wirral
    33 Post(s)
    Trim : Basic
    Engine : 1.6 16v
    Are you getting a good supply of low pressure?
    Have you got fuel all the way to injectors?
    Sep 2010
    LEEDS
    how can i check if theres fuel all the way to the injectors?
  1. Rear Signum Light problem problem - help
  3. 1 problem sorted and 1 more problem arises
    Last Post: 4th April 2011, 13:03
  4. Bit of a problem, Need Help
    By vectrasri-j in forum Vectra C / Signum Car Chat
    Last Post: 18th January 2010, 19:21
  5. Problem...? Vectra SXI...problem with starting after filling with fuel?
