Results 1 to 3 of 3
Thread: Display Brightness.. Can it be adjusted
    Regular Member Sigmacca's Avatar
    Jun 2011
    Skegness
    Default Display Brightness.. Can it be adjusted
    Have a CD70 Navi, the screen/display appears quite dim, can the brightness be adjusted in any way?
    I am aware of the Auto/Day/Night in settings and have it set to 'Day'
    Thank you all
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    It ajusts together with instrument light
    Jan 2012
    Milton keynes
    Trim : M Sport and Design
    Mileage : 38100
    Theres a little push in/pops out dial by the light switch on the right, should be 2 dials I think. Just push it in, it pops out, twist and hold left or right to brighten/dull the screen. The other dial, unless you have xenons is for headlight level.
    Also, if you go through the setting on the cd70, theres options to default the brightness etc... so have a play and see what you find. Should be listed in the audio manual.
  1. Headlight brightness tip
    By Teapot in forum Vectra C / Signum Car Chat
    Last Post: 6th January 2011, 12:18
  2. Sat Nav brightness
    By 111 in forum Vectra C / Signum Car Chat
    Last Post: 7th November 2010, 20:55
  3. Has anyone adjusted their Egr valve ??
    By DeanF in forum Engine & Drivetrain
    Last Post: 13th March 2008, 10:03
  4. Centre Screen Brightness
    By DeathStar in forum Electrical & ICE (including SatNav)
    Last Post: 15th November 2007, 19:23
  5. Can the handbrake be adjusted on rear discs?
    By 2ltrT in forum Vectra C / Signum Car Chat
    Last Post: 24th September 2005, 20:12
cd70 navi brightness
how to adjust screen brightness on cd70
2004 astra display brightness
opel vectra lcd brightness
how to change brightness of display on vauxhall astra
vauxhall astra display to brightness
vauxhall insignia screen brightness
vauxhall insignia 2010 nav brightness
screen brightness insignia
vauxhall insignia 2016 display brightness
vectra sat nav dark screen
brightness opel
vauxhall insignia insrrument brightness
vaux astra display brightness
