Results 1 to 10 of 15
Thread: Sidelights as DLR
    Feb 2012
    Southampton
    Default Sidelights as DLR
    Hi. Does anyone know how to use just the front sidelights as DLRs?
    Ideally I'd like just the front sidelights to illuminate with the ignition key, I was gonna replace the existing bulb holders with some containing led bulbs and tuck the redundant holders out of the way, however this of course will trigger bulb failure warning. I can't exactly tuck the holders out of the way with bulbs in and empty they'd trigger bulb failure.
    Any ideas much appreciated.
    2003 vectra 2.2ls
    I am here: http://maps.google.com/maps?ll=50.917167,-1.294137
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    I've tried it mate. Can't be done as far as I know.
    You get the sidelights on with the ignition key, but the dips come on with the engine
    Unless anyone knows differently
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    just have the activated with opcom or tech 2
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Quote Originally Posted by paulvectrac View Post
    When I had mine done by Vauxhall, they couldn't do sidelights only? The dips come on with the engine
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Can't be done mate I've tried. Can get side lights with ignition and dipped with engine on
    Dipped with engine on
    Or fog lights
    Can't get side lights which I was disappointed about
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    It is totally possible.
    Do you want the tail lights on too, or just front side lights?
    It may not be possible through programming the particular module, but it would be possible by just doing a little wiring.....
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Ste, how would this be done?
    ---Sent from my iPhone 4 using Tapatalk
    Feb 2012
    Southampton
    Fronts only. Don't see the point of rears for DLR. Happy to do wiring. Just need a way to do it without upsetting canbus bulb failure.
    I am here: [ame="http://maps.google.com/maps?ll=50.917165,-1.294315"]Google Maps[/ame]
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    I wanted my rear lights on to. I agree can be done with wiring extra. But think I'll just stick to switching them on
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    I can't find a wiring diagram of the light switch so cannot tell you exactly which wires you need to connect to. I must have removed the program that I had, the one that has all the wiring diagrams and lots of other Technical Information about Vauxhall cars....
    But, you just need to connect a switch live to the output wire of the light switch when side lights are selected (using a diode to prevent undesirable things happening if you switch the side lights on without ignition)
    But, this will also power up all the normal lights that come on when sidelights are selected on the lightswitch.
    Or the other way would be to take this switched live to the front lights and connect up with a diode connected into the existing wire. This will just power up the front side lights and the diode will prevent the rears. Not totally sure about bulb failure warning with this method though,
  1. None LED sidelights
    By ridgers84 in forum Electrical & ICE (including SatNav)
    Last Post: 22nd January 2012, 02:34
  2. sidelights
    By The Gas Man in forum Vectra C / Signum Car Chat
    Last Post: 3rd December 2011, 17:02
  3. led sidelights
    By decks in forum Vectra C / Signum Car Chat
    Last Post: 3rd November 2011, 16:22
  4. what sidelights???
    By damadom in forum Electrical & ICE (including SatNav)
    Last Post: 1st April 2009, 02:38
  5. L.E.D sidelights
    By storey_3000 in forum Vectra C / Signum Car Chat
    Last Post: 22nd December 2006, 20:08
