Thread: 1.9cdti Diesel fumes inside the cabin
    Mar 2011
    Bulgaria
    Question 1.9cdti Diesel fumes inside the cabin
    I found it is common for the Opel diesel engines, however i did not found solution of this problem.
    1) Car running good and have full power
    2) At some point cooling fan of engine heat exchanger start, this causing much fumes to come up from the engine compartment. No any fumes visible in engine compartment unless cooling fan running
    3) Starting of the cooling fan come with increased fuel consumption as per BC (on standby 3-4 l/h from normal 0.8 l/h)
    3) Cooling fan do not stop even if outside temp is -10C, and water temp drop below 70C, max observed is 90C
    4) Trouble code indication come up on dashboard. However the report from OPCOM only says:
    **********************ECU ID STARTS**********************
    Source Address: ECM
    Source Address: 0x000007E0
    Identifier: 0x075D
    VIN: W0L0ZCF6851089095
    System name: Z19DTH
    Hardware number:81011616
    Part Number:55197150
    Software version number: WJOAS150_S
    Hardware manufacturer number: 0281012534
    System description: 1037A50284P319_O90
    System description: BOSCH0100
    Type approval number: B05010
    Hardware key number: H000004934
    Programming Date: 20070723
    System description: 0x00006094
    Alpha code: AD
    Software version: O90JTD75
    ECU variant coding: 0x0000FBC0
    Number of stored fault codes: 1
    P0380 - Glow Device General Error
    (08) - Not present
    **********************ECU ID ENDS**********************
    5) Fumes and increased fuel consumption stopped if you turn off/on engine
    So maybe the fumes are from the flex exhaust pipe, but why the fuel consumption increasing.
    East Ayrshire
    Trim : SRI XP1
    I'd be opting for changing the coolant thermostat and getting the flexi pipe checked. Looks like two seperate problems. Thermostat = Cooling fan on and poor fuel consumption because the engine isn't running at fuel temp. Fumes from the flexi pipe
    Regular Member skip85's Avatar
    Wiltshire
    Vehicle : vectra c estate
    Engine : 1.9 cdti 150
    Mileage : 150000
    Look at fuel filter at back of engine. Ime had a hose go and smelt horrendus!
    Mar 2011
    Bulgaria
    The fumes coming from the foreword part after the cooling fan, and move aft along the charger belt. Till now I was unable to locate the exact place. Now I`m equipped with flashlight so next time I hope to find out. For the last week it come only once when the outside temperature rise up above 0C, and I drive a longer distance.
    https://picasaweb.google.com/lh/phot...eat=directlink
    Unfortunately the fumes are not visible on the picture.
    At this video can be observed at the end.
    I notice that in normal condition (without fumes/no error code on dashboard) fan start running even at 73C (outside temp 0C).
    p.s
    If some one is interested in enabling Bord Computer (BC) can contact me for instruction.
    Feb 2012
    PORTO
    Unhappy fumes in cabine
    I have the same problem on my 1.9cdti ,2006.When temp goes over 88ēc the fan kicks in(which is normal)but after a few seconds i have alot of fumes smell in the cabine and can see fumes coming from the engine.If i switch off the engine and switch it on again it stops leting off fumes.
    Has anyone expereinced the same on the car and what was the problem.?
    May 2006
    scotland
    ribeird, if it is exhaust type fumes,try electrically disconnecting your EGR valve for a couple of weeks and see if the smell reduces or goes away completely (although not recommended if your car has a DPF). If it does, it could be a blocked EGR or worn swirl valves within the inlet manifold which is venting the re-circulating exhaust gas into the air under the hood. When disconnected, the EGR will trigger the EML dash light but will be reset to not illuminated after a period of normal driving with it connected.
    Mar 2011
    Bulgaria
    Problem solved.
    O-ring between Turbo and Catalytic converter. If you suffer this should have some soot around the exhaust manifold steel plate.
    jilava
    The increased fuel consumption on idle is happening because your car probably has a DPF - diesel particulate filter - which needs to clean itself (it's called DPF regeneration) every 1000 Km or so. DO NOT stop the engine while this is happening because the DPF will not clean itself. Instead you should drive the car at 3000 rpm until the regeneration is complete (about 10 minutes). While driving you should see a fuel consumption about 2 times higher then normal. While this happends fumes are much more noticeable and they get inside the cabin while standing still.
  1. diesel fumes in cabin!! now sorted with increased range!!
    By actionman in forum Vectra C / Signum Car Chat
    Last Post: 16th March 2011, 20:04
  2. Fumes smell in the cabin
    By Northy in forum Engine & Drivetrain
    Last Post: 17th January 2010, 19:59
  3. Diesel fumes entering cabin
    By matt_vec2007 in forum Engine & Drivetrain
    Last Post: 14th February 2009, 15:45
  4. Fumes in the Cabin
    By bennyk in forum Diesel Engine related
    Last Post: 11th December 2007, 13:54
  5. diesel exhaust fumes in cabin
    By marky2027 in forum Engine & Drivetrain
    Last Post: 19th November 2007, 20:52
vectra c diesel fumes in car
08 vectra 1.9 cdti diesel fumes in car
vectra cdti cabin fumes
zafira 1.9 cdti diesel fumes in cabin
