Thread: Signum Wiper problem, arm scraping screen
    Feb 2011
    hampshire
    Default Signum Wiper problem, arm scraping screen
    Help hope this is the right place to post this? its my first time on this site.
    The spring link underneath the hinge on the drivers side wiper arm on my signum elite 2005 has started touching and now make a squeal against the screen. This only happens as arm reaches the end of the wipe across to the offside. Vauxhall say it needs a new arm but I fail to see how this will make any difference although I have ordered one. I have slighly bent the blade end of the arm closer to the screen in order to lift the hinge point end further away but this has made little difference. I think I have checked all the threads on this site but no one seems to have had a similar problem. I did remove the arm (it was very tight) needing a puller and I have looked under the plastic shroud but all looks ok, however there is a small amount of play in the spined shaft bearing. There could be more play when the arm is vertical but I cannot stop the wipers in that position to check. I also noticed if you pull the arms out as when washing the screen the hinge sides also scrape the screen if the wipers are switched on. Any advice gratefully received.
    Engine : 1.9 CDTi
    No idea..............
    Where in Hampshire are you as we could compare ( I am in Havant)
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    oi lee calm down compare lol
    Engine : 1.9 CDTi
    If he shows me his I will show him mine
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    everyone backs to the wall
    Regular Member DonnieDubh's Avatar
    Jul 2011
    Fortwilliam Highland
    Having the same prob bought a new wiper on way home but when investigated the hinge spring was scraping at 1 point on the window of my vectra off to play with it the now.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Is the arm fitted correctly to the drive spindle coming up through the skuttle panel? Can the whole thing be moved up and down (ie in and out of the skuttle?)
    If the wiper arm has to correct shape, then it could be the wiper linkage.
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Jul 2011
    No play in arm or linkage so removed drivers arm and reshaped the metal at the hinge attached to the spring .
    Say reshaped actually hit it with a hammer and then repainted black lol
    Arm + Hammer = NO SCRAPE
    wiper working well
    Thanx for the reply Ste
    Jul 2011
    Double Post
  1. Estate rear wiper Scraping!
    By MadOnVaux! in forum Electrical & ICE (including SatNav)
    Last Post: 1st October 2012, 15:36
  3. new screen now screen wiper problem
    By kenno31 in forum Bodywork & Interior
    Last Post: 18th February 2012, 12:34
  4. Signum wiper problem
    By neilb1 in forum Vectra C / Signum Car Chat
    Last Post: 26th July 2011, 22:03
