Thread: Aftermarket Stereo Fitment.
    Regular Member tgarrett's Avatar
    Apr 2009
    Newton Aycliffe
    Default Aftermarket Stereo Fitment.
    56 plate vectra did have a CD30, Full can.
    I got myself a decent stereo and im have a 'mare fitting it.
    I got a new quadlock adapter fakra cable all ready to plug and play. Thats not the case.
    I plugged the quadlock in and... nothing. I got power as i heard the CD spin up. I dont however have any display on the stereo.
    I fiddled about with the wires and the best i can get is a constant connection (stereo wont go iff once iv turned the ignition off) or nothing.
    What am i doing wrong!!
    Iv had a look for a 'How 2' and iv had a search for any ideas but im drawing a blank.
    Dec 2011
    Woking
    Trim : Exclusive
    Engine : 1.8vvt (Z18XER)
    Mileage : 58000
    Check the menu options on the CD radio unit - there may be an option to switch between ignition / non ignition operation.
    Otherwise it's looking in detail at the pin-outs - normally there is permanent 12V and a switched ignition 12V and you have to match up the connections from car side to the radio side. Some radios don't have all the options - in which case wire up the ignition supply to the radio so it only operates with the ignition on.
    Apr 2009
    Newton Aycliffe
    The quadlock i got didnt have the switched (red) wire conected up although it was there. The constant (yellow) was in place but it met up with the red wire from the car side.
    I have messed around with different wire positions but like i say the best i can get is a constant.
    From the car side, on the plug i have, from left to right, top to bottom:
    Blank - Green
    White - White
    Red - Blank
    Yellow- Brown
    Do the green and white need to be connected to anything maybe?
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Either join the red and the yellow up mate of put an ignition live on the red one
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Is the facelift the same as half can cars? If so there is no ignition live in the loom. You will have to take it from another feed like the cigi lighter.
    Sent from my Sony Ericsson Xperia using Tapatalk
    Apr 2009
    Newton Aycliffe
    Boom!
    http://www.vectra-c.com/forum/showth...t=58334&page=2
    Thats what i was looking for. Although i have blown a fuse messing around with the wires so gotta fix that first.
    Regular Member 0114NIGEL0114's Avatar
    SHEFFIELD
    I had the same prob with my head unit and I swapped the red and yellow round on the head unit so the red on the head unit went to the yellow on the car and yellow on the unit went to red on the car u sorta get the jist
    Apr 2009
    Newton Aycliffe
    Yeah that was the first thing I did.
    Its not that simple by the sounds of things. Ill get to the bottom of it.
    Apr 2009
    Newton Aycliffe
    Double posy!
  1. aftermarket stereo cut out
    By Allan-DTI in forum Electrical & ICE (including SatNav)
    Last Post: 19th June 2012, 19:55
  2. oem stereo fitment
    By marktaylor in forum Electrical & ICE (including SatNav)
    Last Post: 16th March 2011, 09:05
  3. Aftermarket Stereo
    By GazVXLINE170 in forum Electrical & ICE (including SatNav)
    Last Post: 14th July 2010, 07:16
  4. Corsa stereo fitment
    By scott_150cdtisri in forum Electrical & ICE (including SatNav)
    Last Post: 17th January 2007, 16:41
  5. Stereo fitment
    By redbullkid in forum Electrical & ICE (including SatNav)
    Last Post: 14th September 2006, 09:27
