Thread: Coil Pack & Plugs
    Full Member
    South West
    Default Coil Pack & Plugs
    Hey folks,
    Got the car back from having its LPG installation yesterday (ill post pics and thoughts in the LPG thread)
    The chap who did the installation said that when he was doing the tweaking of the LPG ECu, recommened that better fuel consumption/and general running could be achived if i replaced the coil pack and probably the plugs.
    Plugs i am happy with, they are quite straight forward
    Now, what is a coil pack? and are they an easy item to install yourself?
    Are they expensive? Its on a 2L Turbo engine btw.
    I have done a few searches and prices seem to vary quite a fair bit up and down. If i am going to replace, is there a recommended one for my particular engine?
    Sorry for my igonrance!
    Regular Member disco dan's Avatar
    Apr 2011
    Southport
    anything around £100 for a new GM one, VX quoted me £136 but ive seen them the bay for £80.
    Full Member
    South West
    Cheers,
    So, is there anyway i can figure out which one might be causing the problem? Would a OBD Code Reader give me any indication... I can get my hands on an Autel 509M if that would help.
    Doing a bit more searching, it appears they are pretty straight forward to replace... even for me!!
    Full Member
    South West
    Bit of a shameless bump i'm afraid...
    Anyone with an idea on how to check if a coil pack is on its way out or not working at optimum?
    Dec 2011
    Seaham
    As coils kick out over 50,000 volts, they arent really user testable. garages may be able to test them?
    Normal signs of a failing col, would be a misfire and if you compared the plugs, the duff coil would mean you would not be getting a full spark and therefore probably not such a good burn.
    WGAF#5
    Things You'll Need
    Voltmeter
    1
    Open the bonnet
    2
    Locate the coil pack in your engine by following the spark plug wires from the spark plugs; the wires are connected to the coil pack. Depending on your particular vehicle model, you may find the coil pack mounted on one side or the back of the engine.
    3
    Unplug the spark plug wires from the coil and label the wires if necessary for proper installation.
    4
    Unplug the pack's electrical connector and remove the coil pack from the engine, using a wrench or ratchet and socket if necessary.
    5
    Set your ohmmeter to the 20000 ohms range. Turn on your meter and touch the spark plug wire terminals on one of the coils with the meter leads. You may get a reading between 5000 to 15000 ohms, depending on your particular model. This checks the secondary resistance.
    6
    Set your ohmmeter to the 10 ohms range, and touch the terminal B+ (usually the center prong on the coil pack electrical connector) with one of the meter test leads, and touch the corresponding coil prong on the electrical connector with the other test lead. You may get a reading between 0.3 and 1.0 or more, depending on your particular model. This checks the primary resistance on each coil.
    7
    Repeat steps 6 and 7 for each coil in the pack assembly, and compare your resistance readings to the specifications given on your vehicle service manual
    If your readings are out of range, replace the coil or coils as necessary.
    Full Member
    South West
    Cool! If its dry tomrrow ill give it a go and see what the results are.
    Would never have known unless the LPG install guy had mentioned it. No sign of a misfire or anything, but his LPG ECU Mapping software said it showed it up and said it could be causing the engine to consume more fuel. So certainly worth checking out.
    Thanks for the reply
    Rgds
    Aidi
    South east
    There's no coil pack on the 2.0T, there are 4 individual coils.
    Full Member
    South West
    Yep, found that out mate, i guess i could have worded it a bit different.
  1. New coil pack or Plugs
    By Niall83 in forum Engine & Drivetrain
    Last Post: 23rd June 2012, 20:36
  2. Check coil pack/spark plugs Signum 2.2 direct
    By siross69 in forum Engine & Drivetrain
    Last Post: 17th May 2012, 15:00
  3. Spark plugs and coil pack
    By pogvec in forum Engine & Drivetrain
    Last Post: 17th February 2012, 22:23
  4. Spark plugs, coil pack and rocker cover gasket
    By ridgers84 in forum Vectra C / Signum Car Chat
    Last Post: 2nd February 2012, 19:12
  5. plugs or coil pack help!!!!!!!
    By rick1965 in forum Vectra C / Signum Car Chat
    Last Post: 14th June 2009, 00:31
