Thread: advice needed
    Regular Member chrosty's Avatar
    Jul 2010
    lincolnshire
    Default advice needed
    hi guys i was driving down the motorway yesterday when my hand brake light came on and stayed on untill i had stopped and turned my car off. when reading my vauxhall book it states that it could be my brake or clutch fluid levels? is this true? what should i do to solve the problem?
    all help needed and appreciated cheers ben
    Regular Member Das's Avatar
    Turdsville
    35 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    Well Id check the brake fluid level and if that's fine whip the front passenger wheel off and check the brake pads as this this is where the brake pad wear sensor is.
    Jul 2010
    lincolnshire
    cheers mate ill check it out.
    You have an SRI
    There are two brake warning lights
    The smaller one is for the handbrake
    Is it this one that has appeared?
    If so, then it is the brake fluid level, and this warning light stays on once activited for low brake fluid level
    It can often be a false reading when near the minimum and driving up or down severe gradients
    The larger one will appear in the Rev Counter
    If so, then it is (front nearside) brake pad sensor warning
    Jul 2010
    lincolnshire
    it was the one for my brake fluid level which was low, but once i topped it up my brother told me that it sounds like my dmf is on its way out which isnt very good. so best start saving up cos i hear this isnt a cheap fix?
    Quote Originally Posted by chrosty View Post
    Just purchase a good third party warranty, that covers both the DMF and clutch, and have it in place
    That will then be cheaper and can then be used as other wear and tear items fail
    Jul 2010
    lincolnshire
    what sort of third party warranty do u suggest?
    My company has a tie-in with AA so I bought this before my car expired
    The AA Repair Breakdown policy is ideal, just check the policy to ensure it covers DMF and respective clutch destruction
    Phone any and all warranty companies you are considering, list the known issues to see if they cover them
    Jul 2010
    lincolnshire
    i think ive got something like that through the AA. it covers for the repair of anything that breaks on the car but im unsure what it actually covers? and i cant find my policy?
    VOTING UKIP IN AVELEY
    5 Post(s)
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    worth giving them a ring m8 ...the AA usually have a seperate warrenty for parts covered, your probibly just on a breakdown one .
  1. Advice Needed
    By Doddy01 in forum Vectra C / Signum Car Chat
    Last Post: 4th November 2010, 15:35
  2. a little advice needed please
    By mublin in forum Vectra C / Signum Car Chat
    Last Post: 26th August 2010, 16:11
  3. advice needed
    By iasha in forum Vectra C / Signum Car Chat
    Last Post: 10th July 2009, 10:42
  4. advice needed
    By taxidriver50005 in forum Bodywork & Interior
    Last Post: 1st June 2009, 15:30
  5. advice needed
    By lizard in forum Electrical & ICE (including SatNav)
    Last Post: 12th November 2008, 19:36
