Results 1 to 10 of 11
Thread: Stupid question time.... Servicing
    Regular Member ridgers84's Avatar
    Jan 2012
    Derby
    Default Stupid question time.... Servicing
    Morning all. I'm wanting to start servicing my veccy by myself. I have already changed the spark plugs and coil pack and have ready an air, pollen and fuel filter to replace. What else needs doing for a proper service? The car had its pads, discs and brake fluid all changed last march. I know it will need the oil changing too.... Think I will struggle on doing the oil and fuel filter, will a Haynes manual show me how to do this?
    Sent from my iPhone using Tapatalk
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Oil and oil filter
    Dependant on age/ milage coolant and gearbox oil?
    After that case of stripping and cleaning brakes. And f
    Then generally going around and checking bushes for play etc.
    Regular Member bigdave1701's Avatar
    York
    Oil & filter really isn't that hard to do on the drive (unless you're a but tubby like me). depending on engine and filter location, the fuel filter can be tricky but do-able with a little patience.
    Regular Member vxpenfold's Avatar
    Nov 2010
    sittingbourne,kent
    Vehicle : Vectra Hatchback
    Trim : Life(well it was)
    Mileage : 166000
    tbh the biggest part of a service isnt the changing of filters it is the safety inspection, if your not confident in inspecting a vehicle for serviceability enlist the help of a friend who has the knowledge/experience or get a garage to do you an inspection
    South east
    You've got a petrol engine, so the fuel filter will be quite easy. Oil changes are also easy, but if you're a novice then put a polythene dust sheet under the car to protect your driveway from spills.
    lincolnshire
    get a decent drain pan too , and torque bit set thats not made from chocolate , always warm the car up before dropping the oil , IF its an element filter ? you'll need a big enough socket to undo the lid which should only be 25nm but will be way tighter than that , good luck , once you get the hang of it its easy
    Jun 2006
    Kirkintilloch, Scotland
    Quote Originally Posted by vxpenfold View Post
    Strongly agree. As this is carried out for an MOT I regard the this test as part of my annual service. Debate?
    Dave
    Jan 2012
    Derby
    I have a 2008 1.8 vvt (z18xer) with 62k on the clock. Would you recommend coolant with this age/mileage? I have a friend who can help with a safety check. Thanks for the advice guys keep it coming.....
    VIP-Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 Vtec
    Mileage : 64500
    Quote Originally Posted by ridgers84 View Post
    The Red/Orange OAT Antifreeze has a minimum service life of 5 years. As long as it tests lower than -28 its fine, this has more to do with anti corrosion property's than outright frost protection.
    Regular Member GoldenWonder's Avatar
    Durham
    Just out of curiosity why are you changing the coil pack?
    Is it high mileage or do you have a misfire or similar problem? Theres no service interval for changing the coil pack as far as I know.
  1. Servicing time again
    By jacko52 in forum General Chat
    Last Post: 23rd November 2010, 22:05
  2. stupid question time.....
    By bobby-tupper in forum Vectra C / Signum Car Chat
    Last Post: 6th May 2009, 22:08
  3. stupid question but...im stupid..
    By nicj in forum General Chat
    Last Post: 18th March 2009, 23:00
  4. stupid question time......
    By coylo5 in forum Vectra C / Signum Car Chat
    Last Post: 22nd August 2007, 07:29
  5. stupid stupid stupid question- 3.0dti badge
    By Adamdavi3s in forum Styling
    Last Post: 17th August 2007, 06:32
