Results 1 to 10 of 23
Thread: Gsi decat
    Regular Member larrysSRI's Avatar
    Nov 2009
    south wales
    Default Gsi decat
    I've owned two Mondeo v6 st24s and and replaced the main cat with a decat pipe and saw good results on the dyno and mot emmisions were not affected. Is this the same with the Gsi? The two pre-cats will remain.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    If the CDTI is anything to go by it's the pre cats which do the bulk of the restricting but I can't be utterly sure about the 3.2.
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    The 3.2 is the same, you can decat the main cat as long as the pre's stay and it passes emission fine. Although arn't the new regs going to stop all this even oil burners? If I remember rightly a physical decat is out of the question now even if emission are fine.
    May 2011
    bispham, blackpool
    my mot garage when i asked just told me to knock all the inside of the cat out that way when a tester looks the cat is still their and it passes the new regs
    Regular Member Jaspa's Avatar
    Nov 2010
    nottingham
    Trim : GSi
    Engine : Z32SE
    Year : 53
    Mileage : 57,000
    As above yes can remove the main cat fine and will still pass emissions due to the 2 precats remaining. though these cause most of the restrictions not the main you may gain a few bhp and abit of noise but will lose a fair bit of midrange torque also new MOT regulations state that any exhaust system minus factory fitted cats (pass emissions or not) will fail so if your going to do it get a fabricator to make the pipe flanged so you can remove and refit for MOT
    VIP-Member GSiFan's Avatar
    Houghton Regis, Bedfordshire
    19 Post(s)
    Vehicle : Vectra GSi 3.2 V6
    Trim : GSi
    Engine : Z32SE
    Mileage : 216,400
    Somebody out there is selling decat pipes that look like catalytic converters. The new MOT regs do indeed prohibit removal of any catalytic converter, even if emissions are not affected.
    Paul
    2003 Vauxhall Vectra GSi 3.2 V6
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Quote Originally Posted by GSiFan View Post
    Paul
    But the emissions WILL be affected, otherwise why is it fitted in the first place if it does nothing?
    TBH, the machines at MOT stations are a bit of a joke. When you talk about REAL emissions measuring kit that cost hundreds of thousands of pounds it makes the MOT tester machine look a bit pathetic.
    Anyway, I am glad that the MOT will include a check for the removal of standard fit emissions reducing devices, as I think it is immoral to remove them.
    Removing the guts may actually decrease performance as the expansion and contraction of the exhaust gas in the 'can' may increase backpressure and can actually be worse than having the cat fitted......
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Quote Originally Posted by Ste View Post
    that's your opinion.
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Some is my opinion as a professional Engineer working in new engine development, and some is fact.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Yep. (tumbleweed)
  1. 2.0 dti decat help?
    By kieronlee in forum Diesel Engine related
    Last Post: 2nd April 2011, 19:54
  2. 2.0 dti decat
    Last Post: 28th March 2011, 10:21
  3. decat 2.2 sri?
    By davaroo in forum Petrol Engine related
    Last Post: 17th March 2011, 19:48
  4. to decat or not to decat a gsi - is it worth it?
    By TimTay in forum Petrol Engine related
    Last Post: 21st January 2011, 21:25
  5. 3.2 V6 GSI Decat.... Is this ok??
    By VinnyPeewee in forum Petrol Engine related
    Last Post: 26th November 2007, 22:01
