Results 1 to 10 of 28
Thread: Help! Oil Overfilled by Kwik Fit, Advice needed!
    Feb 2012
    merseyside
    Default Help! Oil Overfilled by Kwik Fit, Advice needed!
    Hello All,
    I had an oil change done at kwik fit 3 months ago (since done 2000 miles) on my 2007 vectra 1.8vvt. Today, the emissions warning light illuminated, which has never happened before. i checked the oil level (first time since the change) and noticed it is above the max level and approx 5 inches up the "wire" part of the dipstick!!!!!!
    Could this be the cause of the emissions warning and could the overfill have caused any damage to the engine?
    Any advice what my best course of action would be? should i take it back to kwik fit or would it be better to have a vauxhall dealer take a look first? Obviously if kwik fit are to blame then i want them to pay to put things right!
    Regular Member keith1983's Avatar
    Sheffield / Spalding
    Vehicle : Vectra 1.8 SRi
    Engine : Z18XE
    To be honest mate I think 3 months down the line is too late to be going back with this sort of thing. Give it a try by all means but I can't see you getting anywhere.
    Full Member plasma's Avatar
    On the Forum
    346 Post(s)
    Engine : 150
    Mileage : 74000
    did u clean and recheck the dip stick a few times, oil can splash up from the engine running, happened on mine the other day... It would cause the emissions light to come on, not sure what it would do on a petrol engine (plasma dont do petrol) but on diesel engines it can be very dangerous. It would probably just get over the top of the pistons and burn it off as blue smoke?
    Regular Member MrDerv's Avatar
    Nov 2011
    North East (Beamish)
    Quote Originally Posted by keith1983 View Post
    I agree, 3 months without checking the oil level could be deemed as a failure of "Basic Checks" by yourself. Proving otherwise wouldn't get very far due to the time lapse from service to checking.
    I'd see about getting the oil drained, measure the quantity to see how much overfill there is, then refill with fresh oil.
    Feb 2012
    merseyside
    Yeah the dipstick was cleaned several times (on level ground with engine off for several mins).
    I assumed the oil level would be correct following the oil change so i have had no cause to check it untill the emissions light came on, I couldnt believe my eye's when i saw how far up the dipstick the oil level is showing!
    do you think the emissions light will go off if i get kwik fit to drain the excess oil? or is it likely that some damage has occured? I am absolutely fuming with kwik fit right now!
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    IF the oil was 5 inches up the dipstick, im pretty sure you'd of known about it a lot less than 2000 miles ago!
    if its overfilled that much with oil, you'd know almost immediately as the oil gets sucked up into the bores and it smokes like hell.
    al.
    Feb 2012
    merseyside
    i haven't notice any smoking at all and it's definately 5 inches up the dipstick (difficult to see because the oil is so clean/honey coloured)....
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Lesson learnt though!! Check oil level at least once a week.
    Is all other levels ok?
    Oct 2011
    Essex
    Not H/G is it? As for Kwik Fit's fault, I think thats laughable.
    Sep 2011
    West Mids
    Surely 5" up the dipstick would mean a full sump?? That would make one hell of a noise as the crankshaft went splashing around in it. Not sure you could even drive a car with that much oil in it without any massive signs of something wrong
  1. Replies: 7
    Last Post: 29th June 2011, 12:02
  2. Overfilled the engine with oil
    By whelp in forum Engine & Drivetrain
    Last Post: 30th April 2011, 21:46
  3. Overfilled with oil
    By tjsignum in forum Engine & Drivetrain
    Last Post: 9th March 2009, 22:06
  4. Overfilled Oil on 2.8
    By Raze in forum Engine & Drivetrain
    Last Post: 8th October 2008, 06:43
  5. Advice needed
    By bgm46 in forum Electrical & ICE (including SatNav)
    Last Post: 26th October 2007, 21:37
