Results 1 to 10 of 11
Thread: fault codes?
    Regular Member farley2708's Avatar
    antrim n.ireland
    Default fault codes?
    had the dreadded limp mode on my way home in my 05 1.9cdti 150
    got the codes up on a laptop
    P1109-61................UNKNOWN
    U2105-00................no communication with ECM
    U2105-71................ECM message range performance
    any help would be great,just put 4 new shoes on her today....................so more money required then
    Full Member Niall83's Avatar
    Nov 2009
    Belfast
    bump anyone?
    AirBox Mod-Angel Eye head lights-HID 5000k-Colour coded grill-GID to CID-Auto Dim rear view Mirror, Rear Parking Sensors, Signum Fog surrounds, 19" Audi A5 rep Alloys, Eibach 30mm Pro-kit Lowering Springs.
    Administrator plasma's Avatar
    On the Forum
    368 Post(s)
    Engine : 150
    Mileage : 74000
    P1109 is swirl valve i think.. not good probably jammed..
    other 2, clear the codes and see if they come back... they are data comms problems, maybe a spike. see if they are still present when cleared
    Jun 2009
    South Coast
    Vehicle : Vectra, Signum & Insignia
    Engine : Z18XE,Z19DTH,Z20NET,
    P1109-61 - indicates a fault with the swirl throttle actuator.. have a look down at the inlet manifold, there should be a rod with 4 connectors onto the manifold, common for falling off apparently
    U2105-00 - possible shagged ECM, may need to be replaced, reprogrammed. Not cheap either way.
    U2105-71 - not sur eon this one but it seems to refer to the BCM as being the issue
    Check your battery is in good condition before getting too deep into this.. this can cause the last two
    The wifes vec show car is currently being stripped for parts before i scrap it, keep an eye on the sales section.. https://www.vectra-c.com/forum/garage_vehicle.php?do=view_vehicle&id=709
    Sep 2011
    West Mids
    P1109 - Secondary Port Throttle System
    Check out this site. It's a .NL site but lists full codes in english
    http://www.opel-forum.nl/viewtopic.p...7943&start=125
    Nov 2009
    Belfast
    Cheers guys
    Regular Member peadar's Avatar
    Aug 2007
    in the glens of Antrim N Ireland
    Vehicle : ELITE
    Trim : FULL LEATHER
    Engine : 1.9 CDTI 150 BHP
    Mileage : 87,000
    Nige if your bar is still on try cleaning the egr valve and throttle body
    Nov 2009
    Belfast
    well all sorted now??
    Jun 2009
    South Coast
    Quote Originally Posted by peadar View Post
    The only bar I have issue with is coz of the crap beer while I watch the rugby.
    Nov 2009
    Belfast
    Quote Originally Posted by Caveman_nige View Post
  1. fault codes
    By GSi-Col in forum Electrical & ICE (including SatNav)
    Last Post: 10th March 2012, 00:00
  2. fault codes
    By ADAM123 in forum Engine & Drivetrain
    Last Post: 31st January 2012, 19:02
  3. Fault Codes
    By tony100la in forum Vectra C / Signum Car Chat
    Last Post: 10th November 2010, 09:49
  4. Fault Codes
    By cdms811 in forum Vectra C / Signum Car Chat
    Last Post: 15th November 2007, 14:17
