Thread: Cylinder Head Bolts
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Default Cylinder Head Bolts
    I had a bit of a strange phone call yesterday at work.
    We are doing some testing at an external test establishment.... on a new engine development. As I am the project manager for this new engine, the test Engineer suggested to the test technician he calls me (as he was on holiday).
    The upshot was that they needed to refit the head, but the bolts had been used the specified maximum number of times - ie 3.
    We do not have any spares, we could get some for Tuesday (as they are not available in this country). The testing is quite important, but we want any testing to be done robustly, accurately and correctly.
    So, what would people's opinion be on what to do?
    I will answer later what course of action was taken.
    East Midlands
    I'm surprised that you actually used the bolts on 3 separate occasions Ste i was always lead to believe that they stretch when installed on the first fitment or is that old hat now.
    Engine : 1.9 CDTi
    Depends on the stretch bolts.
    Some bolts you measure and if they are longer than the set value they cant be used but if under they can.
    If they say they can only be used 3 times I would take it at that but I am sure they would be fine but you never know how long for,
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Yes, they still stretch, but single use is just too damn expensive.
    Regular Member benny's Avatar
    Feb 2006
    dudley
    cut a small amount of the bottom and reuse one last time ....place a "shim" washer under the head .....
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    The technician was absolutely right to ask for new bolts, as the old ones had been used the maximum number of times specified - ie 3.
    The bolts were inspected by an Engineer. The way to check for bolts that can be reused is to measure the stretch area - the non-engaged threads stretch the most and stretch fairly evenly up to the shank of the bolt.
    By using another bolt as a guide, using the engaged threads to compare the stretch on the other bolts, it is easy to see how much stretch has occured at the threads nearest the shank. If this stretch is less than about 25% of the thread pitch the bolt can be re-used. If it's much more, then it can't.
    These were M10x1.5 so if the stretch was less than about 0.4 mm they would be OK to re-use.
    As they were all less than this, and the bolt heads were not damaged (either scored, or bent) and the bolts were straight and hadn't 'necked' the engine was re-assembled and the tests continued.
    HAPPY DAYS !
    Benny, I don't understand why you would cut off some of the engaged threads and put a shim under?
    spoons
    Guest
    Quote Originally Posted by Ste View Post
    Blag the last test results and pretend you did it. Get your subordinate to sign it off and go make some tea
    (joke )
    Dec 2011
    Seaham
    Fit new bolts, a lot of work to strip an engine, it doesnt make economic sense not to wait and use new bolts.
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    I've never used a set of head bolts more than once. Every single time I've had a head off I've replaced the bolts with new and then followed the appropriate tighten/heat up/re-tighten procedure for the relevant engine.
    Snapped one once even using new and still within the correct torque, ended up having to take the whole thing back off and get a company out to extract it from the block for me.
  1. Cylinder head
    By GCusdin in forum Engine & Drivetrain
    Last Post: 20th September 2012, 11:11
  2. is my Cylinder Head going
    By jinkie in forum Engine & Drivetrain
    Last Post: 4th January 2012, 09:25
  3. Cylinder Head
    By T4M in forum Vectra C / Signum Car Chat
    Last Post: 1st May 2008, 15:35
  4. Cylinder Head
    By Matt21385 in forum Engine & Drivetrain
    Last Post: 18th February 2008, 17:42
vectra c diesel head bolts
