Thread: car wont start? :(
    Oct 2009
    southport
    Vehicle : vectra
    Trim : sri
    Engine : 3.2 v6
    Angry car wont start? :(
    hi all, my vectra 3.2 v6 2003 has been stood for about 7 months now i do start it regually, last time i moved it was begining of jan 12 just been out to start it while we are having this cold spell, took battery out of my regular car which use to be in the vectra and it just clicked so put battery on charge to make sure it had full charge put back in and clicked again sometimes it will go to turn over the engine but after it just starts to turn it will click again.... i have also tryed jumping it off another car and the same happens!! i just dont know what to do so you guys help please,,
    ps it did do this when i was using it aswell but turned over and started after like 5th go
    Cheers Ben
    wirral
    32 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Do you have a multimeter? What voltage are you getting at the starter?
    Is the battery of the correct ampage?
    Regular Member XPCobra's Avatar
    Dec 2010
    Glasgow
    Vehicle : Vauxhall Vectra Hatch
    Trim : SRI with added X-Pack
    Engine : 1.9 16v 150
    Mileage : Near 100K
    Sounds like a faulty starter motor, or possible high resistance in the starter motor wiring ( damaged wires)
    wirral
    32 Post(s)
    Trim : Basic
    Engine : 1.6 16v
    Quote Originally Posted by XPCobra View Post
    That's my thinking.
    Thinking more dodgy solenoid with it eventually starting
    Northampton
    Engine : A20DTH
    Mileage : 88000
    You need to check that the battery u are using is the correct amperage, ie powerful enough to start the car. just because you take a battery from another does not mean it will be the correct amperage to start the car
    Oct 2009
    southport
    Vehicle : vectra
    Trim : sri
    Engine : 3.2 v6
    thanks everyone, still got the issue, i got a battery that was powerfull enough and still clicking!! got to be the starter, i bumped it yesterday and started fine let it run abit turned off then started on the key first time a couple of times go to start this morning click again!!! anyone got a pic were the starter motor is or a how to on removing or checking connections? can see it anywhere
    thanks Ben
  1. wont start
    By wsophiecat in forum Engine & Drivetrain
    Last Post: 17th December 2011, 17:17
  2. 2.2 cut out now wont start
    By spink1972 in forum Engine & Drivetrain
    Last Post: 22nd April 2011, 08:32
  3. Car wont start - please help
    By zafira in forum Diesel Engine related
    Last Post: 6th November 2010, 14:25
  4. Will not start then it will then it wont????
    By djconfused in forum Engine & Drivetrain
    Last Post: 29th July 2010, 21:37
  5. car wont start!
    By briancdti in forum Vectra C / Signum Car Chat
    Last Post: 11th November 2008, 20:11
