Results 1 to 10 of 11
Thread: fault p0100* but only when engine warmed up
    Feb 2012
    leicester
    Default fault p0100* but only when engine warmed up
    Hi all
    got a problem with my 2005 2.0 dti , if i rev past 3200rpm when the engine has warmed up i get fault code p0100* show up putting on the spanner warning lamp and putting car into limp home mode .
    if i turn eng off and restart everything is ok untill i rev beyond the 3200rpm again.
    it only does this once the car has warmed up , when cold the engine will rev past this point with no faults at all.
    i have replaced the maf with another bosch one but the fault is exactly the same.
    i can,t see any obvious faults with pipe work and when reving the car the hoses do swell under pressure and i cant hear any sound of a leaks . also the wiring loom looks ok with no sign of problem.
    any ideas ?
    Rob
    Regular Member Keefyb007's Avatar
    Jan 2010
    Berkshire
    Mass or volume airflow malfunction according to iPhone app
    Feb 2012
    leicester
    have replaced the maf and its still exactly the same , any other things to try ?
    north east
    whats the milage on it ?
    one possibility is tone of the boost pipes from the intercooler split / leaking pressure check all the clamps are tight.
    Feb 2012
    leicester
    mileage is 120,000 have checked the pipes in situ not removed them but they seem o.k swell up when eng rev,d with no sound of any leaks on them .
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    P0100 Mass or Volume Air Flow Circuit Malfunction
    As the word 'circuit' is mentioned, have you checked all the wiring and plugs for any damage, water ingress or electrical breaks?
    Feb 2012
    leicester
    have checked visually , but it only does it when eng warm .... its fine when cold ? seems a strange fault as if pipe or wiring faulty surely the fault would occur when the eng was cold too ?
    i was wondering if a component was overheating ?
    anybody got any ideas or had the problem before?
    north east
    crank shaft speed sesors only die when warm some other sensors as well its basic science wire cold = circut closed, wire hot + slight break = error code.
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    Crank sensors are worse when hot engine
    Feb 2012
    leicester
    i,ve replaced the maf sensor and no difference to fault .....any other sensor which could interfere and create p0100 fault code ?
  1. p0100 Fault 2.2DTI 2004
    By 1TAYLOR1 in forum Engine & Drivetrain
    Last Post: 24th April 2012, 22:05
  2. Fault Code P0100
    By dhwigston in forum Engine & Drivetrain
    Last Post: 1st August 2011, 06:46
  3. Fault code P0100, AGAIN!!!
    Last Post: 1st June 2010, 14:20
  4. any 1 else got this wierd sound when ar warmed up!!!!
    By vectramad in forum Vectra C / Signum Car Chat
    Last Post: 22nd October 2008, 21:11
  5. Fault Code P0100
    By vectra2004 in forum Troubleshooting
    Last Post: 27th May 2008, 19:08
