Thread: Help removing interior bulbs
    gwent
    confused Help removing interior bulbs
    Hello what's the best way to remove the reading interior light bulbs I can't get a grip on them I tried a tweezers with blue tack on it but still no joy and how do you change the rear interior bulbs
    Regular Member larrygroke's Avatar
    Feb 2011
    Plymouth
    Vehicle : vectra c
    Trim : Exlusive
    I've changed mine...with a struggle i have used tweezers and fingers! or long now plyers also work
    Dec 2011
    Seaham
    Try long nose pliers but with some rubber tape around the tips, it will help grip the glass.
    gwent
    Well I got the front ones change I used surgeons grip pliers but now I can't remove the rear interior light I read you need to slide it and pull but it won't come out
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    Easiest way to change the front map reading lights is to undo the three torx bolts and drop the whole light unit down. You can just untwist the bulb fitting and pop new ones in then
    Regular Member Yenyaw's Avatar
    Feb 2012
    Hemel Hempstead
    What bulbs are these and how many?
    Gonna change mine for white as they tend to be brighter, but need to know how many to get and what type.
    Feb 2012
    Hemel Hempstead
    gwent
    You need six 501 type bulbs four for the front and two for the rear but when i changed the bulbs in the rear they did not work for some reason so put the old ones back in
  1. Removing interior plastic?
    By firefox007 in forum Bodywork & Interior
    Last Post: 20th May 2011, 12:31
  2. Replies: 9
    Last Post: 22nd December 2010, 01:46
  3. Removing front map reading light bulbs?
    By SAS32 in forum Bodywork & Interior
    Last Post: 28th March 2010, 09:27
  4. Removing interior panel behind light
    By spatch in forum Bodywork & Interior
    Last Post: 11th July 2008, 23:17
  5. Removing interior light bulbs on SRI - er how???
    By stehanson in forum Vectra C / Signum Car Chat
    Last Post: 1st December 2006, 15:48
