Results 1 to 10 of 19
Thread: boost pressure sensor
    Feb 2011
    lisburn
    Default boost pressure sensor
    Hi all, got ab problem with my y30dt I have replaced the boost sensor and am now getting the fault "boost pressure sensor high output" have any of you came across this problem? and what the solution is car kicking into limp mode under acceleration. Any help would be appreciated
    Cheers Ian.
    Regular Member CristianTM's Avatar
    ROMANIA, Eastern Europe
    Try to get out the ECU, open it and check all bad contacts !
    CristianTM.
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    Quote Originally Posted by iwtand View Post
    Cheers Ian.
    Fault code P0105-3 by chance?
    Regular Member beat275's Avatar
    Aug 2011
    Newcastle West Denton
    Vehicle : Hatch
    Trim : SRI
    Engine : 2.0T
    Mileage : 90000
    Disconnect the battery for half an hour that should sort it
    Feb 2011
    lisburn
    Hi Beat, tried the battery thing but still not cured
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    What's the numbers of the fault code Ian?
    Does it come out of limp mode when you're not accelerating and is the spanner light and EML light on?
    wirral
    39 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    What readings are you getting from sensor? Ie voltage and what boost is it saying? Was sensor genuine?
    Feb 2011
    lisburn
    Hi guys, had the car at mates garage today I did not write the code down but think it was the p0105-3 but not 100% sure and yes the sensor came from stealers cost me £76! I have no eml light but have the spanner the car only seems to do this on accelerating to around 75mph and when I switch off and restart it goes back to normal running
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Ian - so you boot it and the spanner light comes on but does it stay on when you stop and let the engine tickover? As an aside, before you switch the engine off after going into limp mode, what's the tickover speed - 740rpm (normalish) or 1000rpm.
    Feb 2011
    lisburn
    Light out when restarted tick over before turning off 1000rpm on restart around 800
  1. boost pressure sensor input and output voltage???
    By FLOB in forum Engine & Drivetrain
    Last Post: 24th April 2012, 14:58
  2. 2.0 dti boost pressure sensor
    By jono m in forum Engine & Drivetrain
    Last Post: 3rd January 2011, 12:08
  3. Boost pressure sensor screw thread
    By Godzilla in forum Engine & Drivetrain
    Last Post: 5th June 2010, 20:59
  4. boost pressure sensor
    By johnbattams in forum Engine & Drivetrain
    Last Post: 26th March 2009, 17:40
  5. Boost Pressure Sensor
    By vectravirg in forum Vectra C / Signum Car Chat
    Last Post: 15th November 2007, 12:52
