Results 1 to 10 of 11
Thread: Washer fluid leaking
    Regular Member monty2000's Avatar
    Sep 2009
    swansea
    Vehicle : Vectra C Pre Face, Colour Coded, CR Tech Box, Pipercross Panel filte, Blanked EGR :-)
    Trim : Club
    Engine : 1.9cdti 16v
    Default Washer fluid leaking
    Not sure if ive posted this on the right part of the forum.
    But anyways my vec (pre facelift) has developed a washer fluid leak.
    It appears to be coming from underneath the fluid bottle somewhere.
    It started the other day then stopped even after topping it up again.
    Looking this morning & theres 2 icicles haninging underneath the car
    Is there anything common that fails?
    & looking at it the bumper has to come off to get near it. Am i correct?
    If so any linkys on pre facelift bumper removal would be greatly appreciated
    VIP-Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 Vtec
    Mileage : 64500
    Did you fill it right up to the top? The rubber grommet around the filler neck can leak. Reduce the amount of fluid in the tank and see if it still leaks. Other issues could be the level sensor grommet is leaking or the tank has cracked if the washer fluid has frozen.
    Sep 2009
    swansea
    Trim : Club
    it was leaking b4 we had the cold spell so i dont think its cracked the bottle. it does stop when the fluid gets very low.
    Dec 2011
    Seaham
    Check the pump mounting rubber, its possible it is perished?
    Sep 2009
    swansea
    Trim : Club
    does the bumper have to come off then?
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    Quote Originally Posted by monty2000 View Post
    not neede... but very much easier if you do..
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    You can get access from under neath - so no the bumper does not have to be removed.
    The washer pump slide up and out of the bottle. The pump has the valves on the side and pipes to the rear or front windscreen washers. This simply pulls off the pump and pushes back on. Maybe leaking from the grommet into the bottle (which is also the filter for any crud in the bottle)
    11 Post(s)
    HOW2 to access and clean the filter (rubber grommit)
    Sep 2009
    swansea
    Trim : Club
    theres a plastic panel underneath. cars to low (or im too fat lol) to get underneath properley to see how it comes off.
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    There was no need to remove the inner wheel arch cover on my car, I just reached up from in front of the car.
    The pump / valve / diverter assembly on my car is different to that in the how 2.
  1. brake fluid leaking signum 3.2v6
    By david106 in forum Suspension, Wheels & Brakes
    Last Post: 27th May 2012, 21:25
  2. Brake Fluid Leaking On to Foot Pedal
    By user999998 in forum Engine & Drivetrain
    Last Post: 12th May 2011, 13:27
  3. gearbox fluid leaking ?
    By pro auto valet in forum Engine & Drivetrain
    Last Post: 25th October 2010, 19:59
  4. Which washer fluid?
    By vxvirgin in forum Vectra C / Signum Car Chat
    Last Post: 3rd April 2009, 08:15
  5. Is this a leaking brake fluid bleed nipple ?? (pics)
    By simac in forum Suspension, Wheels & Brakes
    Last Post: 16th December 2007, 20:10
washer fluid leak vauxhall vectra
