Thread: DIY'ers and home insulation.
    Leeds
    Default DIY'ers and home insulation.
    Hi - anyone any thoughts / recommendations on this. Our living room and conservatory floors and rooms in general always feel cold. I've pulled back the carpet / underlay and the floors are just chipboard. I'm guessing that a lot of the cold just comes up through here and makes the rooms feel cold.
    I'm wondering if it would make any noticeable difference if I put a layer of 5mm fibreboard as used with laminate flooring down first, then put the underlay and carpet back down - as a fairly easy and cheap DIY job?
    There's no noticeable drafts now either ... as I spent an age sorting all those out!
    Thanks - J.
    spoons
    Guest
    I used to have laminate flooring throughout my house (previous owner did it). I eventually replaced all the upstairs bedrooms with carpet and underlay.
    I removed all the fibreboard with exeption to the front guest bedroom as its over the internal garage. (Cold radiating from below) so I left the fibreboard down, then underlay, then carpet.
    I cant honestly say I've noticed any difference other than you have to step up 5 mm into the room from the landing (because its slightly higher with the fibreboard underneath). Which means the door had to be shaved a bit more on the bottom to clear the carpet.
    Its certainly not cold in that room, but I dont know how much that contributed as I also fitted the loft out with Natural Sheeps Wool loft insulation around the same time, and had new windows fitted
    South east
    Quote Originally Posted by julian924s View Post
    What's under the chipboard? If it's joists and then a gap to the ground below, you should fill the gap between the joists with rigid insulation.
    Regular Member wardy23's Avatar
    Nov 2011
    North Yorkshire
    Vehicle : vectra
    Trim : sri
    Engine : 2.2
    Mileage : 64000
    or fill the gap with concrete
    Vectra-C Extreme Poster Big Red's Avatar
    May 2011
    Dudley (Cramlington)
    if it is chip board then im betting its concrete floor mate with waterproof membrane over top then chipboard, hence why its so cold. you can get a special foam to put down under carpet/laminate which is a proper insulating layer makes a hell of a difference like
    Aug 2010
    Leeds
    Quote Originally Posted by Rebellion View Post
    Yeah that stuff with the silver foil on one side.
  1. sound insulation
    By rob1981 in forum Electrical & ICE (including SatNav)
    Last Post: 15th January 2013, 21:25
  2. Engine Sound Insulation
    By Diesel Dude in forum Engine & Drivetrain
    Last Post: 20th January 2011, 22:51
  3. Engine cover insulation
    By old cruiser in forum Vectra C / Signum Car Chat
    Last Post: 30th April 2010, 20:18
  4. Loft insulation and storage
    By JuzzyD in forum General Chat
    Last Post: 27th January 2007, 00:23
  5. Under bonnet insulation
    By SCOTTEX in forum Vectra C / Signum Car Chat
    Last Post: 6th July 2006, 14:46
