Results 1 to 10 of 14
Thread: combi boiler problem ??
    lincolnshire
    Question combi boiler problem ??
    any heating engineers about ??
    the combi boiler my GF has is running way too much pressure and the usual trick of bleeding off from a rad isnt working , does the water need topping up ?? it works as it should and all the rads are hot !
    any ideas or thoughts welcome folks
    Regular Member beat275's Avatar
    Aug 2011
    Newcastle West Denton
    Vehicle : Hatch
    Trim : SRI
    Engine : 2.0T
    Mileage : 90000
    The pressure should read 1 and a half bar so bleed it till it reads that. There the pressure relief valve in the boiler should be a red knob
    Engine : 1.9 CDTi
    When are you reading the gauge as it will read higher if the hot water is running or the heating is on.
    Aug 2011
    Vehicle : Hatch
    Trim : SRI
    Engine : 2.0T
    Mileage : 90000
    Good point forgot to mention that.
    May 2011
    Eastbourne
    Depending on the pressure it reaches, could be a faulty expansion vessel or leaking heat exchanger.
    lincolnshire
    i'm familiar with normal running , it normly needs the pressure boosting via the valve at the bottom and on occasion i've bled the rads a bit to release pressure , but the pressure only drops if i turn it down to " on the water temp setting
    thanks thus far folks
    lincolnshire
    Quote Originally Posted by beat275 View Post
    does it relieve through the over flow when this valve is used ??
    Dec 2011
    Seaham
    Is the boiler filler valve actually open and constantly feeding the boiler??
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    Quote Originally Posted by Ben50n View Post
    Good point . Flexible hose (aka "fill loop") should always be disconnected to prevent backflow and accidental overfilling. If they're ball type isolating valves on the fill loop (there's usually two, one each end of the hose), these have a tendency over time to either 1) not isolate properly or 2) leak from the ball part of the valve.
    I'd tend to disconnect the fill loop and relieve the pressure to around 1.5bar when the system's cold.
    lincolnshire
    will check all these after work and report back
  1. Boiler sorted !
    By bembo449 in forum The 'Off Topic' room
    Last Post: 22nd July 2011, 22:23
  2. Combi Boiler!
    By djr69uk in forum General Chat
    Last Post: 5th March 2011, 02:04
  3. combi boiler ?
    By rickeys16v in forum General Chat
    Last Post: 7th September 2010, 22:39
  4. Baxi Boiler problem
    By Ste in forum The 'Off Topic' room
    Last Post: 30th October 2008, 12:25
  5. Help...Combi Boiler
    By Damian in forum General Chat
    Last Post: 13th April 2006, 18:48
