Results 1 to 10 of 20
Thread: temp gauge ?
    slough
    Default temp gauge ?
    hi people what temp does your vectra c run at mine is
    56 plate 1.9 cdti 150 bhp facelift and runs @ 82.5
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Between 85 and 90
    V6 cdti
    East Midlands - Regional Organiser new boy's Avatar
    Nov 2010
    lincs
    63 Post(s)
    Vehicle : Exclusive
    Trim : Vxr half leather
    Engine : 1.9 cdti
    Year : 56
    1.8vvt
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    85C for the CDTI 150.
    slough
    confused
    so do i need to change thermostat if im only getting 82.5 max.
    11 Post(s)
    It does sound low.
    What stereo you got?
    You might be able to go into the hidden test mode and see what the temp is.
    eg, if a CD70, press and hold the Settings button until it tells you that test mode is on, then press the BC button a few times to get to the relevant page that shows the temp.
    slough
    confused
    i have the six cd multi changer with dab radio and trip computer cant remember model no` can i adjust the temp from there though, i thought that it only adjustable from changing the thermostat. p.s it used to be hot in the car on level 2 on the fan with the temp control set to max. just lately i noticed that even with the fan on 4 on the motorway just dont seem realy hot, not noticed what the temp normal runs at.
    Aug 2010
    Leeds
    Mine is owt from 82 to 86 depending on how cold it is and it sits outside all night no garage.
    Those parked in garages warm up quicker.
    1.9 cdti 120
    11 Post(s)
    Quote Originally Posted by hippo View Post
    No. It is a read only display that gives you a more accurate reading than the guage.
    At speed no 4 you're probably taking out all the heat from the system. The faster the air flow through the heater matrix, the less time it has to get warm.
    slough
    temp gauge went to 0 whilst driving today then went to 85 on the motorway then back to 80 off motor way...... ganna try new stat tommorow.........
  1. temp gauge on 1.8
    By MID LIFE CRISIS in forum Engine & Drivetrain
    Last Post: 14th January 2010, 22:10
  2. rev counter/speedo/temp gauge/fuel gauge stopped working
    By bloodworm in forum Electrical & ICE (including SatNav)
    Last Post: 19th July 2009, 00:28
  3. Outside temp gauge
    By sberrow in forum Vectra C / Signum Car Chat
    Last Post: 26th August 2008, 20:47
  4. temp gauge
    By cow monkey in forum Electrical & ICE (including SatNav)
    Last Post: 3rd June 2007, 16:22
How to alter settings on vectra cd70 trip computer when in test mode
