Results 1 to 10 of 15
Thread: Comfort v Wheel size??
    Wirral, UK
    Vehicle : Mokka
    Trim : SE - Orange Rock 's !!
    Engine : 1.7CDTi
    Default Comfort v Wheel size??
    Is a 16" wheel with 215/55/R16 tyre the same ride as a 17" wheel with 215/55/R16 tyre??
    Are 17" wheels a more bumpy ride, compared to 16" wheels??
    Macclesfield
    Vehicle : Focus
    Trim : Titanium
    Engine : 1.6 TDCI
    Year : 62
    Mileage : 9K
    Yes 17" will be more of a harsher ride than 16".
    Regular Member Jow20's Avatar
    Sep 2010
    Leeds
    Not much!!! If any! Try jump from 16's to 19's then you may notice a difference
    Jul 2009
    Brighton
    The larger the profile, the more comfort you'll get. (remember, the profile is a percentage of the tyre width).
    The tyre acts as part of the suspension and helps absorb the bumps and knocks. The downside is there is more flex and so the handling is compromised. Ask anyone on here with 19" snowies what the ride is like.
    Sep 2010
    Leeds
    19's are not that bad like some make out!
    Oct 2011
    Essex
    Quote Originally Posted by TonyP2020 View Post
    Same profile? Should the 17" not be on a 50?
    8 Post(s)
    If you try fitting a 17" tyre onto a 16" wheel, you'll never blow it up as there will be a gap between the rim of the wheel and tyre.
    Wirral, UK
    Vehicle : Mokka
    Engine : 1.7CDTi
    Quote Originally Posted by andrew e View Post
    Yes it should, to maintain the overall wheel diameter.
    A 17" wheel with a 55 profile will be 25mm/1" bigger in diameter overall.
    Which is one reason why I'm looking at doing it, as the engine revs will be slightly lower at the same speed.
    I realise that this will affect the speedo and mileage reading.
    Plus there is a greater choice of tyres for 17", including Neuton's.
    Wirral, UK
    Vehicle : Mokka
    Engine : 1.7CDTi
    Thanks Dave, I hadnt noticed this typo.
    Bet it has been tried tho'.
    Hopefully the video will be on Youtube.
    May 2011
    bispham, blackpool
    25mm or 1" doesnt seem alot but you will notice it your car is going to be 25mm higher to start with
    going 25 30mm lower on suspension you notice the difference so doing that going higher with tyres it has to effect the handling as the car is higher more roll etc
  1. wheel nut size
    By chewy71 in forum Vectra C / Signum Car Chat
    Last Post: 17th October 2012, 08:26
  2. wheel size
    By booner in forum South Central (RO - Harrysdad, ARO - matty2fatty)
    Last Post: 16th February 2012, 23:32
  3. Wheel size and tyre size
    By DSmiddy in forum Vectra C / Signum Car Chat
    Last Post: 14th December 2011, 19:19
  4. sri wheel size
    By andsaw in forum Vectra C / Signum Car Chat
    Last Post: 11th May 2010, 18:33
  5. wheel well size
    By shan in forum Vectra C / Signum Car Chat
    Last Post: 14th December 2007, 18:41
