Thread: rear view camera
    Regular Member eminemme42's Avatar
    Jan 2012
    westmidlands
    Default rear view camera
    hi guys just thinking of fitting a rear view camera for the mrs in a veccy c 54 reg sri any ideas on how to go about it on routing cables and any help would be greatfull and whereto take power fromm
    thanks pete
    Regular Member john506's Avatar
    Mar 2011
    Wirral
    Just a case of fitting camera in the back, screen in the front and finding a route for the cable. When I installed my reverse parking sensors, I routed the cable from the back light unit, to behind the rear seat, then down under the carpet and up inside the centre hand rest, along bottom of drivers seat then tucket it into plastics by the clutch pedal. Just got to get the wire and see what you can do, it gets harder depending on how much you want to hide the wire.
    If you wanted the camera on all the time when you start the car, maybe tap into an ignition or 12v supply cable somewhere, if you wanted it on only when you put the car in reverse, you would need to tap into the cable feeding the reverse light.
    Jan 2012
    westmidlands
    Default reversing camera
    cheers john i need a wiring diagram for a 54 veccy sri 150 1.9cdti if possible i would like it to come on when reverse is engaged so she can see and no excuse then
    pete
    Regular Member yysnet's Avatar
    Jul 2010
    Scotland
    Take the power from reverse light then.
    Jan 2012
    westmidlands
    from the rear light cluster when u engage reverse gear it will pover it up
    Regular Member Zark's Avatar
    Herts
    Don't forget links to the camera and screen you get, and pics when fitted!
    Jan 2012
    westmidlands
    got a single din kenwood flipout screen just waiting to get the stalk controls and facia plate i need not too long i hope the standard stereo is pants lol
    Regular Member scotty84's Avatar
    Dec 2010
    Boosting in W.Mids
    Vehicle : Saab 9-3 Aero
    Trim : Aero
    Engine : 2.8 Turbo V6
    Mileage : 62000
    I fitted my reverse camera a month back to my pioneer double din headunit. The camera is a replacement rear numberplate light really clever lol.
    I had to run 2 wires from the headunit to the boot (1 is av in and the other a remote wire)
    AV to the camera
    Remote wire to reverse + on rear light
    Then camera power to reverse + on rear light
    Camera negative to ground on rear light.
    I ran the wires from HU behind glovebox, down by passengar feet then tucked them away down the plastic trim to the rear seats, then under seat, then inside the side void (where fuse box is) to rear light....Easy peasy took me about 30 mins to do. There is a rubber gromit in the boot to feed the camera wires through from outside to inside.
    As your west mids buddy get bits you need and come to our Fix it day on 26th Feb at mine in Telford and I will give you a hand or if your not to far from me I will come and show you the way lol.
  1. Rear view camera with my Pioneer?
    By Mark2.2 in forum Electrical & ICE (including SatNav)
    Last Post: 27th November 2011, 16:38
  2. help connecting power to a rear view camera
    By cornel18 in forum Electrical & ICE (including SatNav)
    Last Post: 7th February 2011, 15:03
  3. rear view camera
    Last Post: 19th March 2010, 09:15
  4. Rear view camera
    By mileff in forum Electrical & ICE (including SatNav)
    Last Post: 5th March 2010, 22:22
  5. advice on rear view camera
    By tony stoney in forum Electrical & ICE (including SatNav)
    Last Post: 20th January 2010, 22:14
vectra c install reverse camera www.vectra-c.com
