Thread: Power Steering Fluid Replacement.
    Regular Member Keif's Avatar
    In the Garage
    Default Power Steering Fluid Replacement.
    Has anyone replaced their Power Steering Fluid? Done a search but not found anything useful.
    Is it a case of Front Bumper/Offside wheel arch liner off (to get to the reservoir). Remove the feed and return pipes to drain the fluid. Or is there a drain plug.
    Then refill, then bleed
    (Start the car for 5 seconds, turn off. Restart and turn the steering wheel from lock to lock 5 times)
    Also the "bottle" is very opaque and I currently can't see any fluid level. Is it easy to replace. While the system is empty I may as well sort it.
    I can see a couple of How 2s coming when it's a little warmer.
    Thanks for any pointers.
    In the Garage
    No one done this then?
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 85000
    Keif the only references to changing PS fluid ive seen was to basically buy one of those huge syringes add a bit of tubing to them an suck it out through the top of the tank.
    Hmmmmmm maybe another good excuse to buy one of these.....
    http://www.ebay.co.uk/itm/4L-SYPHON-...c#ht_599wt_698
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    I've got the exact one. I last used it to drain the last of the water out of the cistern before I fitted a new flush. I mainly use mine for bleeding brakes and the clutch, blow one end and suck the other.
    Yer Maws Bedroom
    40 Post(s)
    Engine : 1.8 iVtec
    Mileage : 85000
    In the Garage
    Done this today.
    How 2 submitted.
    Regular Member james chambers's Avatar
    Sunny Leicestershire
    Trim : SRI
    Engine : Y22SE
    Mileage : 100,000
    Ive done a couple at work Keif if you get stuck in future give me a ring!
  1. Power steering fluid
    By dittohead in forum Vectra C / Signum Car Chat
    Last Post: 23rd March 2011, 12:50
  2. Which power steering fluid ??
    By FatboySteve in forum Suspension, Wheels & Brakes
    Last Post: 16th February 2011, 10:07
  3. power steering fluid
    By dilan in forum Vectra C / Signum Car Chat
    Last Post: 14th September 2010, 09:46
  4. power steering fluid ??
    By bobbyboy in forum Vectra C / Signum Car Chat
    Last Post: 22nd August 2006, 17:14
  5. Power Steering Fluid
    By MLC in forum General Chat
    Last Post: 28th June 2006, 13:09
https:www.vectra-c.comforumshowthread.php155566-Power-Steering-Fluid-Replacement
How to drain power steering fluid vectra c
vectra c power steering fluid change
