Thread: Handbrake tighten
    Aug 2010
    London
    Default Handbrake tighten
    Hi there
    I have just replaced the discs and pads on the rear of my 2003 vectra c 1.8 and i was wandering do i need to adjust the handbrake. Currently the handbrake works but it goes up to about 5 clicks to lock the wheels dead,(might get away with 4 but it not completely dead locked).
    Does the handbrake self adjust after a few times or does it need reset or something??
    Wondering lonely as a cloud
    26 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    Press and hold the button in and activate the handbrake several times and pump the brake pedal that should do it but it doesn't sound to far away mate.
    Aug 2010
    London
    thanks for the reply dude
    i just tried what you said. I pulled it a few times softly and harder but it didn't seen to change. Pumped the foot pedal and it when harder after a few pumps as it should
    its not to bad just wandering is there a way to get a little tighter for the mot or is 4/5 clicks average.
    26 Post(s)
    Vehicle : M5
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    4/5 clicks is fine its not excessive and the wheels lock on 5 so it works but the system is self adjusting
    Aug 2010
    London
    cool so through the next few days it should settle down? Hand brake used to lock tight on 4 before but with the old pads and discs it moved up to 5.
    Sure as long as it passes the mot and is safe.
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 65500
    It will settle after a couple of days of use. Was the same when I did my pads, soon sorts its self out.
    Regular Member wardy23's Avatar
    Nov 2011
    North Yorkshire
    Vehicle : vectra
    Trim : sri
    Engine : 2.2
    Mileage : 64000
    my handbrake has always been 7 clicks which deffo locks on but just wondering if there is any way of altering this as ive also just replace pads and discs at rear but its still the same
    Mileage : 000
    Did you press the brake pedel first when you changed the rear pads. If you pull the handbrake up first, it uses up all the adjustment.
    Nov 2011
    North Yorkshire
    Vehicle : vectra
    Trim : sri
    Engine : 2.2
    Mileage : 64000
    yep did the brake pedal first
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Can make minor adjustment in the screw on handbrake itself
  1. Tighten Boot Lock
    By barachello in forum Bodywork & Interior
    Last Post: 13th June 2011, 15:19
  2. How to tighten the Aux Belt ??
    By thehoq in forum Engine & Drivetrain
    Last Post: 27th December 2009, 18:27
  3. Dont forget to tighten your lap belt!!!
    By rushy in forum Comedy & Humour
    Last Post: 6th September 2006, 20:26
how to tighten handbrake on vectra c
how to adjust handbrake on vectra c sri
