Thread: Stuck bonnet prob!
    Jan 2012
    Berkshire
    Default Stuck bonnet prob!
    Apologies to mods if this is wrong section but unable to post in tech section as account disabled???
    Bonnet cable stretched Im guessing..did the tighten mod last night and all looked gd, **** bonnet then tried this morning to open and lots of slack on lever, tried pulling cable with pliers..no movement.
    Not really wanting to break grill as its another expense..unless anyone has one spare on here?
    In the process of moving house so this is a right pain, especially as all I wanted t do was oil change..even that is proving diff as can't locate oil filter or see what it looks like.....location, access etc is all unknown..can it be seen from under the car?
    Again apologies for wrong section but account settings wouldn't allow me to post elsewhere...
    Please help!
    [Ex]Admin Duncan's Avatar
    Your account looks enabled so you should be able to post anywhere.
    There are threads on this problem, which I can't recall the solution/outcome was, so if you do a search hopefully you'll find one/them.
    Oh, and
    Jan 2012
    Berkshire
    Hey
    Just tried again to access common vx probs but get the error MSG, not enough privileges or awaiting activation etc....?
    Regular Member GrantAbs7's Avatar
    belfast
    Fella similar happened to me.. after hours of trying to get through the grille etc my da managed to solve the issue by holding the interior release lever fully open while i simply popped the bonnet up. Hope it helps.
    Jan 2012
    Berkshire
    Tried pulling cable and leaver as hard and as much as poss, reached a stale mate now, can't pull wire anymore as it won't move....leaver is hanging out and bounced bonnet, pulled bonnet etc...nothing budging....new grille needed before I smash this one I reckon. Grrrrr
    slough
    big D. in berkshire where are you, and what vectra c bonnet you trying to get up, ive done a couple now and dont do them the damage way..... pm me and we`ll hook up and see what we can do....
    slough
    well the offers there if you change your mind.......
    Regular Member Exclusive BV's Avatar
    West Midlands
    Sounds like a decent offer to me,
    Would you mind sharing your methods or is it a trade secret?
    May 2011
    Scotlnd
    The cable on my Veccy became unattached and I was able to release the bonnet by using a bent wire coat hanger through the front grill, it only took seconds.
    http://i1092.photobucket.com/albums/...r/IMG_1555.jpg
    Dudley
    Default Can't open bonnet
    Hey Trainspoter, I've tried this method with no success. I'm not quite sure what I'm 'feeling' for. Does the coat hanger go over the top of the grill with the little hook you made aiming for the centre of the car? I presume the wire goes in from the right hand side of the badge?
  1. HELP! Bonnet Stuck
    By Danwells72 in forum Bodywork & Interior
    Last Post: 12th April 2012, 19:34
  2. Bonnet Stuck !!
    By jimbojetset in forum Vectra C / Signum Car Chat
    Last Post: 20th January 2012, 14:34
  3. bonnet stuck
    By hippo in forum Vectra C / Signum Car Chat
    Last Post: 20th May 2011, 06:51
  4. Bonnet Stuck
    By suj786 in forum Bodywork & Interior
    Last Post: 16th May 2011, 21:07
  5. bonnet stuck
    By old cruiser in forum Vectra C / Signum Car Chat
    Last Post: 14th February 2009, 21:21
