Thread: info screen dimming
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    Default info screen dimming
    the gid dims when i turn the steering wheel.
    the fan also slows down slightly too?
    what can be the cause of this.
    al.
    Dec 2011
    Seaham
    Is this on tickover?
    I beleve the power steering is electrically assisted and causing a power drain??
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    yeah its usually on tick over but i dont think it should dim as much as it is.
    also it slows the fan down so somethings not right.
    iv just put a brand new 100ah battery on so i know thats ok.
    al.
    Dec 2011
    Seaham
    Its normal from what I have read, my headlights flicker on tick over when I turn the sterring wheel.
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    steering box uses about 60amps so i have been told so to me this is quite normal for a little flickering so to speak, have you had the alternator tested ??
    Midlands Mod Shop - NFFC.
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    Quote Originally Posted by ditchp View Post
    not yet but it does charge the battery well..
    i think il put it down to a common fault with the looks of it.
    thanks all.
    al.
    Engine : 1.9 CDTi
    More notable if you have the dimmer turned down a bit too.
  1. In dash Info screen
    By Vectra_C_Chris in forum Electrical & ICE (including SatNav)
    Last Post: 2nd February 2012, 02:02
  2. Info screen help
    By GAV_SRI in forum Electrical & ICE (including SatNav)
    Last Post: 6th December 2010, 23:05
  3. how to remove info screen?
    By ronnie63 in forum Electrical & ICE (including SatNav)
    Last Post: 8th July 2009, 17:33
  4. Auto dimming wing mirror info request!!!!!
    By glenboy in forum Vectra C / Signum Car Chat
    Last Post: 18th February 2008, 19:04
  5. Info screen problem
    By steviemac74 in forum Electrical & ICE (including SatNav)
    Last Post: 12th January 2008, 18:54
