Thread: Intercooler on its way out?
    Regular Member BigWilko's Avatar
    Jan 2010
    Barnsley
    Trim : Irmscher Elite
    Engine : 3.0 CDTI
    Default Intercooler on its way out?
    What do you think? does it look like it's sagging to you? Maybe oil on the aircon rad?
    Jun 2009
    South Coast
    8 Post(s)
    Vehicle : Signum & Insignia
    Engine : POS derv
    looks like it is sagging as you say, it probably has some crap build up in the cores.. You can take it off and flush it out and carry on reusing it or replace it with a new one for about £120 ish.. Your car will feel better with a new one..
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    i have seen one that was contorted quite badly but it was still opperational and car ran ok, yours looks a little saggy but if car is running ok i would leave it for now....
    Midlands Mod Shop - NFFC.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    I would check for oil in the intercooler and leaks when you take it off, if nothing is found continue to use it.
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    The one on my old vec was proper saggy. This is not as bad but think i might get a new one.
    Mine has a horrendous mark on the offside, from impact damage in 2007
    It was inspected and was advised just to make a visual inspection each week
    It's been through five services like that, not even a remark or comment made since
    It is vastly more open to the elements than the radiator, but seems to be built to take the abuse
    Personally it is fairly well shielded and you can see how much surface area has effect if you spray a jet wash at it from about 5 metres away through the lower grille
    If it isn't leaking then its working fine. I'd leave it but put the money aside for a replacement if its ever needed.
  1. intercooler?
    By justin32 in forum Engine & Drivetrain
    Last Post: 19th January 2013, 17:09
  2. Intercooler
    By beat275 in forum Vectra C / Signum Car Chat
    Last Post: 2nd January 2012, 12:36
  3. Standard intercooler v front mount intercooler
    By tommytonguedj in forum Engine & Drivetrain
    Last Post: 29th June 2011, 09:58
  4. Intercooler
    By user999998 in forum Engine & Drivetrain
    Last Post: 16th May 2008, 11:02
