Results 1 to 10 of 11
Thread: Carb cleaner while engine running
    Dec 2011
    Default Carb cleaner while engine running
    Hi guys, has anyone tried to spray Carb cleaner into intake while engine is running on a 3.2L?
    We used to do this to our 3.5L Mitsubishi's in Oz. It would clean the whole intake out and the gunk of the valves. The engine would sound nicer and run better after this clean.
    It would want to stall while you spray it in but you just keep the revs up.
    Anyone?
    Regular Member nikroc's Avatar
    Nov 2007
    DERBY
    12 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    I do this on my 2t,and have done on my previous cars..also do this on my motorbikes...
    Feb 2011
    Selby
    Have a look on the can - you'll see (in the case of Wynn's anyway) that it's meant to be used this way as well.
    In the good old days of carbs, we used to use the cleaner more for getting oil and dirt off the carb itself, and for cleaning out the internal channels and jets. Plus a blast down the intake to shift any dirt from the inside of the inlet manifold and back of the valves.
    Now most brands have renamed the product to 'intake cleaner', as there aren't so many cars with carburettors any more. And there's naff all in a fuel injected car's throttle body that requires that level of cleaning. Plus modern engines run a lot cleaner anyway...
    Be careful spraying it down the intake on a diesel though - it can lead to runaway, which if you've ever seen it happen, is a very bad thing!
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    Quote Originally Posted by rich r View Post
    can you elaborate a little more on the RUNAWAY please....
    Midlands Mod Shop - NFFC.
    Regular Member Mopar Man's Avatar
    herts
    Quote Originally Posted by ditchp View Post
    Yea a Diesel will rev right up on its own and knock like f--k.
    Trim : Get a
    Quote Originally Posted by Mopar Man View Post
    cheer's for that mate, thought as much but nice to be clarified
    Regular Member Paul_NI's Avatar
    Mar 2011
    Northern Ireland
    do you spray before or after the MAF?
    Regular Member beat275's Avatar
    Aug 2011
    Newcastle West Denton
    Vehicle : Hatch
    Trim : SRI
    Engine : 2.0T
    Mileage : 90000
    I spray after the maf
    Regular Member MrDerv's Avatar
    Nov 2011
    North East (Beamish)
    After
    Feb 2011
    Selby
    Diesel runaway happens when a diesel engine starts running on it's own engine oil rather than diesel from the injectors. Once it's going - it'll just get faster and faster until it either seizes or puts a conrod through the side of the block. Usual causes are too much oil in the sump, or a diesel leak into the sump (from a mechanically driven fuel pump, less likely on modern common-rail diesels), or a leaky injector dribbling diesel in all the time. Effectively oil droplets find their way up the breather system and into the intake - giving a nice mix of fuel and air independent of the fuel injectors.
    Turning off the ignition switch won't achieve anything, as it's no longer running on diesel from the injectors. If you're a bit over enthusiastic with carb cleaner on a running diesel, you can rev it to the point at which it starts churning the oil in the sump enough to spit droplets up the breather pipe.
    Some good videos on Youtube - for example: [ame="http://www.youtube.com/watch?v=5zx3qKX_Pno"]Runaway Diesel Defender 200 TDI - YouTube[/ame]
  1. carb cleaner or engine degreaser? (egr related)
    By gotlosi in forum Engine & Drivetrain
    Last Post: 29th April 2012, 18:35
  2. carb cleaner
    By beat275 in forum Vectra C / Signum Car Chat
    Last Post: 9th September 2011, 00:18
  3. Carb Cleaner / Inlet Cleaner 150 CDTI
    Last Post: 19th July 2011, 09:50
  4. carb cleaner
    By paul.sessions in forum Vectra C / Signum Car Chat
    Last Post: 20th April 2010, 21:02
  5. Replies: 7
    Last Post: 2nd July 2009, 17:51
