Thread: help!!
    Regular Member jimbo1987's Avatar
    Jan 2012
    southwest
    Default help!!
    hi, ive got a 52 plate vec c 1.8 and got the error code p0420 cat converter efficiency below freshold.. i keep reseting code and it doesnt come on again for about another 100 miles or so it makes it harder to diagnose cause when i do running diagnostics the o2 sensors look good. any1 else had experience wid this problem and do you think its the cat!!
    cheers...
    Jan 2012
    Gloucestershire
    hey Jimbo
    Maybe one of the other guys can help more, but there's some good information on this website, even if it is American!:
    http://www.aa1car.com/library/p0420_dtc.htm
    It may explain why you can get away with 100 miles or so before the fault comes up again. It's kind of saying that either you're upstream and downstream CAT O2 sensors are disagreeing with each other or your CAT isn't working as it should. You may find by dropping the CAT that you find bits of CAT material drop out of it to confirm the fault.
    Please guys, anyone else who has experienced this, help out Jimbo - I'm only speculating!
    Jan 2012
    southwest
    good info cheers!
    wirral
    42 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Do you have live reading of what each o2 sensor is saying?
    Jan 2012
    southwest
    yeah both sensors were ok pre was a wavy line and post was steady...
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    Simple things first, have you given it a really good thrash to clear it out? When was it last serviced?
    Jan 2012
    southwest
    yeah give it a real good thrashin, and done loads of miles in last month goin to london and back (long hard drive up m4). since ive had the car in december ive done oil and filter change, air filter, clutch pedal sensor, fuel filter, and have just done the thermostat tuesday and give it a good flush out.
    i reset eml when i done thermostat and still waitin for it to come on again.
