Thread: cold 1.9cdti (150) normal?
    Jan 2012
    Lincoln
    Default cold 1.9cdti (150) normal?
    My signum's forever cold (ish)!
    I bought it in september and when I found it always took ages to warm up I changed the thermostat. It improved but still seemed a little bit slow - I know diesels usually are but I drive an articulated lorry with a huge engine and it warms up quicker!
    Anyway, as it stands, with the new thermostat and a lump of plastic in front of the radiator, it takes longer to warm up than a 10.5ltr straight 6 truck and when it's up to temp (which it never goes over), it goes down notably when I put the heater on.
    Is that normal?
    Regular Member yysnet's Avatar
    Jul 2010
    Scotland
    This is normal, i drove nearly 4 miles to mcdonalds in a chilly car every morning.
    If you bypass the EGR it will help.
    Sep 2010
    My 1.9 CDTI takes around 7 minutes to get really warm which equates to 5 miles driving
    May 2006
    scotland
    My vectra has always showed the water temp cooling if my heater is anyhthing over the middle speed (in the cold weather). I think the stat is defo needing changed though as it is getting worse than it used to be.
    North East
    I had my thermostat changed on my 1.9CDTi just before Christmas and I can't believe how quickly it warms up compared to what it used to be like! This goes against most of the posts on here but seriously I get warmish air thru the vents after a few minutes/miles of driving from cold/overnight. The temp dial takes much longer to raise but the air itself is warm.
    Aug 2010
    Derbyshire
    They do take ages to warm up the cabin. The colder the outside temp the longer it initially takes to warm up the engine. My temp gauge last night had hardly moved as I got to work (4.6 miles) I drive with the heater off sometimes just to give it a chance to get warmer quicker, ****** cold in there though.
    And yes I've had a new stat.
    Mick
    Oct 2011
    Essex
    I have a £14 BQ 2KW fan heater (with a thermal cut out on an RCD) in the footwell that I switch on when I get up at 5. When I leave 20 minutes later its warm and de-iced
    Jan 2012
    Lincoln
    Thanks all, to be honest I was pretty sure nothing was amiss but I find it amazing how long it takes compared to my truck.
    I'm losing the egr, dpf and having a remap next week so fingers crossed that helps.
  1. 1.9cdti 150 juddery on cold start
    By bigdave1701 in forum Engine & Drivetrain
    Last Post: 2nd February 2012, 21:04
  2. 2006 1.9cdti Cold Starting Problems
    By rjcotterill in forum Engine & Drivetrain
    Last Post: 7th June 2011, 16:15
  3. Cold battery voltage? - 1.9CDTi 16v
    By djr69uk in forum Vectra C / Signum Car Chat
    Last Post: 11th March 2011, 11:29
  4. Vectra 1.9CDTI 150 - Cold Starting Woes
    By robdd1 in forum Vectra C / Signum Car Chat
    Last Post: 8th February 2010, 17:39
  5. How hot does your 1.9CDTi runin the cold weather?
    By merikiito in forum Engine & Drivetrain
    Last Post: 27th January 2009, 22:04
