Thread: fault code
    Aug 2009
    merseyside
    Default fault code
    hi ive got a vectra c sri 150 cdti 06 reg and engine light come on and the fault code is p0650, can anyone help. also the blowers stopped working when this come on. is this normal thanks in advance
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    P0650 Malfunction Indicator Lamp (MIL) Control Circuit Malfunction.
    Odd that the blower stops too....
    Aug 2009
    merseyside
    yeah that come up on the comp how is this rectified? thanks?
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    I have never seen this FC come up. If it is not battery voltage related, MIL Bulb, wiring or then I would 'guess' at a new ECU.
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Fuses? Spike from alt may have knocked some out?
    Aug 2009
    merseyside
    heard possable dry joint will have to check it all out on the wkend
    Full Member Robsey's Avatar
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    Have you done the easy stuff first?
    a) Pull the battery for an hour or so - often clears silly electronic glitches.
    b) Clear the DTC's, and see if that sorts the problem.
    Aug 2009
    merseyside
    Hi robsey no not done that mute give that a go later I Persume clear dtc u mean clea the codes? If so yeah done that last night but come straight bk on. Thanks everyone for advice any more wud be very grateful
  1. Fault code help :(
    By Thom in forum Electrical & ICE (including SatNav)
    Last Post: 4th February 2012, 20:14
  2. Fault code help!!!
    By billy88 in forum Vectra C / Signum Troubleshooting
    Last Post: 22nd April 2011, 16:02
  3. help with a fault code
    By jan65uk in forum Engine & Drivetrain
    Last Post: 15th December 2009, 20:57
  4. Fault Code?
    By CDTi-SRi-Matt in forum Vectra C / Signum Car Chat
    Last Post: 26th February 2009, 21:43
  5. Fault Code?
    By CDTi-SRi-Matt in forum Electrical & ICE (including SatNav)
    Last Post: 26th February 2009, 21:23
