Page 1 of 5 123 ... LastLast
Results 1 to 10 of 49
Thread: Rear Internal Courtesy Light
    spoons
    Guest
    Default Rear Internal Courtesy Light
    Hi all,
    I'm planning to do the rear passenger courtacy lnternal light modification, but for those of you that have already done it, a quick question....
    When you open the doors with the remote locking key, does the rear passenger internal light fade up to the 'On' position, just like the front one does ?
    Or does it just remain 'Off' until someone manually turns it on.
    Or does it do all of the above, depending which option you switch it too.
    It fades just like the front one matey (or at least it does on my pre-facelift)
    spoons
    Guest
    Thanks AJA... I've just been reading the 'How To' thread and it appears I might not have the wiring built in ??? - I'll go and check now....
    Regular Member Ross DTi 2.2's Avatar
    Münster, NRW, Germany
    Mine fades up and down and also comes on when you turn the front one on, was standard on the car. I think facelifts may have a different roof harness so best to check the wiring is actually there before buying the part.
    Regular Member Harry's Avatar
    Uxbridge, London
    can't believe you're only doing this now, this is normally one of the first mods people do.
    but then again, you don't quite fall into that category of normal
    hows the VXRD Evolution fleeces coming along?
    spoons
    Guest
    Ferked it up anyway !!!
    Now I know why I pay people to do these modifications
    .... Going to find a cat to kick !!
    Uxbridge, London
    WHAT!?!?! did you actually cut the lining? i'm sure it can be fixed!
    spoons
    Guest
    Nope.... I was just checking for the wiring... to see if it was there and I found some tightly stuck down ribbon wiring, which had been double folded...
    Whilst trying to free the ribbon from the grip of this double sided tape, I accidently ripped through one of the ribbons
    So I thought "**** It"... and came back in vowing never to mess with the car again
    EDIT: **** knows what I've broke.... does anyone know what that ribbon wiring does anyway ??
    Uxbridge, London
    nope....sorry mate.
    have you tried switching all the rear electrical items on and see if the still work?
    Regular Member Ralph wiggum's Avatar
    Oct 2006
    Bexleyheath, Kent
    Sorry Chaps Does this mean i Can't do this Mod on my Facelift model...I didn't realise the wiring is not there anymore
  1. Internal light bulbs??
    By SlowCoach in forum Electrical & ICE (including SatNav)
    Last Post: 11th October 2012, 07:35
  2. Internal light conversion, help?
    By carperjake in forum Bodywork & Interior
    Last Post: 28th June 2012, 15:27
  3. Rear Courtesy light wiring
    By Street N in forum Electrical & ICE (including SatNav)
    Last Post: 13th December 2008, 02:00
  4. Internal Light colour Changes
    By rickyroo in forum Styling
    Last Post: 10th March 2008, 00:19
