Thanks Thanks:  1
Results 1 to 10 of 21
Thread: barometric/boost pressure
    Dec 2011
    newport
    Trim : SXI
    Engine : 2.2 DTI
    Mileage : 105k
    Default barometric/boost pressure
    Hi all
    just put my 03 2.2 dti on opcom as it keeps getting the spanner light on the dashboard
    it come up with p1105 FA barometric pressure not plausible with boost pressure
    i recently put it on a computer which come up with barometric pressure sensor which i have replaced
    anyone got any ideas? or had the same problem
    thanks in advance
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Where is the barometric pressure sensor located? They used to be located on the ECU, but I don't know where they are on your car.
    Dec 2011
    newport
    Trim : SXI
    Engine : 2.2 DTI
    Mileage : 105k
    its just behind the maf
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Have you removed the MAP sensor and cleaned it? Is the performance of the car right? Any smoke? Fuel economy changed?
    Have you checked the wiring / plug for continuity?
    Jan 2010
    norfolk
    hi where is boost pressure sensor and maf sensor
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    Boost pressure sensor is on the inlet manifold , the maf sensor is inside the maf itself
    and still loving it
    Dec 2011
    newport
    Trim : SXI
    Engine : 2.2 DTI
    Mileage : 105k
    there is no smoke its in limp mode so wont let me rev over 2 1/2k fuel consumption has gone down a bit
    it did say baro sensor/wiring on the first diagnostic check but not after i changed the baro sensor
    Dec 2011
    newport
    Trim : SXI
    Engine : 2.2 DTI
    Mileage : 105k
    the light will occasionally go out and it pulls like a train then
    where is the map sensor located?
    Wirral, UK
    Vehicle : Mokka
    Trim : SE - Orange Rock 's !!
    Engine : 1.7CDTi
    There is no MAP, you have a Barometric Sensor, a Mass Air Flow Sensor and a Boost Pressure Sensor.
    The Barometric Sensor should have a voltage (in op-com) of about 4.0v, anything lower eg, 1.6V, is a faulty sensor.
    Similar voltage on the Boost sensor, and the MAF voltage will rise with the airflow.
    The boost pressure demand and the actual boost pressure are readings to observe.
    It is possible that one hose is off somewhere, or split, and will be OK until the boost pressure rises and forces the hose away away from where it should be, or opens the split, then the boost pressure falls and the split/gap 'heals'.
    And I'm sorry to say that you might also have a failing turbo. That's getting to be a bit of a common fault on here.
  10. Thanks Lao thanked for this post
  11. #10
    Dec 2011
    newport
    Trim : SXI
    Engine : 2.2 DTI
    Mileage : 105k
    dont know if i did it right or not but i got boost sensor as 2.15v and baro sensor as 4.3v
  1. Replies: 26
    Last Post: 14th March 2014, 01:03
  2. P1105 & P0105 Barometric Pressure not plausible
    By Innes in forum Engine & Drivetrain
    Last Post: 15th January 2013, 19:20
  3. Barometric Pressure Sensor - P0105
    By Chris B in forum Engine & Drivetrain
    Last Post: 5th June 2012, 18:50
  4. P1105 barometric pressure not plausible with boost
    By ian mc in forum Engine & Drivetrain
    Last Post: 14th November 2010, 11:49
vauxhall vectra 2.2 dti barometric sensor
location of baromic sensor vectra c 2.0 dti
opel vectra c 2.2 dti boost pressure
