Thread: jiddering and poor mpg
    Dec 2011
    liverpool
    Default jiddering and poor mpg
    Just wondering if anyone could help I've had my car about 2 months now and this has happend 3 times, so I'm just driving normal then all of a sudden the instant mpg goes to about 20 mpg where I'm useually getting atleast 40 and then when I stop at lights you feel a very noticable judder as if its misfiring but it seems to have power as normal, switch the car off and all is fine again also no warning lights come one while this is happening my car is a 2005 1.9 cdti sri 120 estate if that help, many thanks
    Dec 2011
    Seaham
    Is it the DPF recycling?
    Dec 2011
    liverpool
    I haven't got a clue mate, I did have to get my dpf cleaned on my laguna, do you think that coluld be the problem?
    Dec 2011
    Seaham
    Could be or the EGR valve needs a clean, I am sure some of the Diesel heads will be along to help.
    This is just what I have picked up from reading countless threads about misbehaving diesels....
    Dec 2011
    liverpool
    Okay thanks mate hopefully will come along an shed abit more light on it
    Wondering lonely as a cloud
    25 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    Check the door piller on the drivers side and look in the bottom right hand corner for the following 1.30 for DPF not present and 0.8 for DPF present. If your car isn't an automatic it may not have a DPF best to check first
    Jan 2012
    Gloucestershire
    Sounds very much like a DPF regeneration - I think most 1.9 Estates have DPFs as it's something to do with tax on company vehicles.
    paulhb, you probably know better than me, but I thought it was 1.20 for no DPF fitted and 0.50 for DPF fitted?
    If you have a DPF, then the regen cycle works on a differential pressure sensor which is basically looking for a restriction of exhaust gas across the DPF (the section of the exhaust which is collecting particulates from your exhaust gases). When the restriction is high, it forces a regeneration (a late additional post injection which uses more fuel).
    Also, from what I understand, it can also be triggered by some sort of equation within the ECU which takes into account journey duration and miles completed - could be wrong on this one!
    Either way, I don't think it's unusual to see this every couple of fuel tank refills.
    Dec 2011
    liverpool
    Thanks for the help DieselWig and paulhb, I think you may be right DieselWig as my car does have 0.50 on the door piller I'm glad to hear that this can be common because I had a nightmare with the dpf in my lump of s*** laguna just took a differant route home from work with a little motorway run so that should help a little
    25 Post(s)
    Vehicle : M5
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    Quote Originally Posted by DieselWig View Post
    You are right mate for the 150 but on some 120 models they had different numbers (in my post) and the OP has a 120 but at least the numbers tally to show he a DPF and that it is the likely cause
    Dec 2011
    liverpool
    Thanks for the help everyone
  1. My poor poor veccy :(
    By tammyman09 in forum Vectra C / Signum Car Chat
    Last Post: 9th June 2011, 10:46
  2. Would You Say This Is Poor MPG?
    By Si-SRI in forum Vectra C / Signum Car Chat
    Last Post: 7th February 2010, 00:06
  3. My poor car
    By PeteRs in forum Vectra C / Signum Car Chat
    Last Post: 10th June 2008, 17:30
  4. Nooooooo!!!!, my poor, poor car!!
    By Duncan in forum Vectra C / Signum Car Chat
    Last Post: 11th May 2006, 16:32
  5. My Poor Poor Signum
    By Brake buster in forum Vectra C / Signum Car Chat
    Last Post: 30th September 2005, 15:45
