Thread: electrical fault please help
    Jan 2012
    nottingham
    Default electrical fault please help
    hi all
    dashboard lights keep going out, this fault happens whenever it feels like it.
    sometimes when im driving they go off and stay off for a while, then they suddenly come back on.
    other times when you start the car the are off.
    all the lights and indicators etc still work but its just the dash display that keeps going off.
    the car has just been retested for its mot, and just my luck they went off,
    resulting in it failing.
    any ideas welcome or anyone reccomend a auto electrician around the nottingham area, preferbly a cheap one lol...
    Devon
    77 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Moved to correct section
    Irmscher Insignia CDTI 130
    Dec 2011
    Seaham
    Try taking battery off for 30 minutes, this may reset the computer. You will need the code for the radio, which should be on a credit card called a Pass Key.
    Jan 2012
    nottingham
    ok mate will try this and let you know.
    Regular Member VXR Shaneo's Avatar
    Aug 2011
    Scunthorpe
    This is a common fault, mine does it whenever it feels like it, it hasn't done it much a lately but sometimes 2-3 times a day. Apparently it's the CIM.
    Jan 2012
    nottingham
    whats the cim?
    had the battery off now for half hour, got to pop out in a bit so will update later..
    Jan 2012
    nottingham
    its just typical that it does it during the mot retest and i couldnt get it back on,
    so ive now goto have a full mot in 2 days. ripp off
    Feb 2012
    derbyshire
    I had a similar problem and taking apart the block connectors near the bulkhead 2 or 3 times sorted it. dials were falling to zero as well which was cured by the same method at the same time. it helps clean the oxidation off and make a better contact. hope it helps
    Jan 2012
    nottingham
    ok ill give this a try as taking the battery off for half hour had no affect.
    is there anything special you clean the connectors with?
    i know this sounds daft but when they go off i press the hazard switch and sometimes they all come back on, only sometimes tho, weird.
    ill try cleaning the connectors tomorrow..
    cheers
    Regular Member Robsey's Avatar
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    Okay - it is indeed a common failing, especially on the pre-facelift Vectra's
    Usual cures are -
    a) Unplug the ABS module connector, and clean all the pins.
    b) Check fuses F10 and F17 in the fuse box on the passenger side of the dash panel
    c) check all steering collumn earth tags
    d) Not as common as inferred, the Collumn Integrated Module can become defective.
    (This is a module behind the steering wheel, which controls the wipers, indicators, steering geometry, horn and radio controls where fitted).
  1. electrical fault
    By bappy in forum Electrical & ICE (including SatNav)
    Last Post: 3rd August 2012, 18:44
  2. Possible electrical fault...
    By Higgsie1 in forum Engine & Drivetrain
    Last Post: 14th October 2011, 04:07
  3. Help (Electrical Fault)
    By Badger59 in forum Vectra C / Signum Car Chat
    Last Post: 30th October 2010, 19:54
  4. electrical fault
    By :LeeR: in forum Electrical & ICE (including SatNav)
    Last Post: 24th April 2008, 18:14
  5. Electrical Fault !
    By FIL 4822 in forum Vectra C / Signum Car Chat
    Last Post: 29th August 2007, 09:09
