Results 1 to 10 of 14
Thread: Outside Temperature Sensor
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Default Outside Temperature Sensor
    Given that I happen to know it's a balmy 5c outside and the OAT display in my GSi says it's anywhere between 16c and 28c as I'm driving along, I'm getting an idea that the sensor has quite possibly finally had enough.
    Understandable as it's quite likely the original part and has been getting everything the weather and roads have thrown at it since Oct 2004.
    So just out of interest and curiousity....
    I'm assuming it's a bi-metallic type working by variation of resistance due to temperature. So does anyone happen to know the resistance range of a known good sensor at normal indoor room temperature ?
    Engine : 1.9 CDTi
    First o fall check the plug that the bumper loom plugs into as there have been a few that were reading wrong (Mine inc) and it turned out to be the pins in that plug being corroded.
    Regular Member beat275's Avatar
    Aug 2011
    Newcastle West Denton
    Vehicle : Hatch
    Trim : SRI
    Engine : 2.0T
    Mileage : 90000
    how did you clean the plug. mine is corroded to.
    Engine : 1.9 CDTi
    Scrapped the corrosion off the pin and sprayed contact cleaner into the plug.
    Then plugged it in and out loads of times.
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Contacts on both plug and sensor appear clean but I'll give 'em a scrape anyway in daylight.
    The weird part was I put the CD70 into testmode and scrolled to the OAT screen..... disconnected the sensor and the display decided it was 10.5c - impressive given the sensor was on the dash and not attached to anything. Plugged it back in at suddenly it decided it was 26.c ..... then 17c ..... then 23.5c .... eees craaazy !
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Might be worth checking the rest of the harness for damage and where the harness plugs into for corrosion
    Engine : 1.9 CDTi
    Its not the connection at the sensor itself.
    On the prefacelift there is a bigger connector by the passenger fog light.
    See this thread: http://www.vectra-c.com/forum/showpo...76&postcount=5
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800
    Mileage : 126000
    http://www.ebay.co.uk/itm/Vauxhall-O...item4cfe10787e
    -4 in birmingham at the mo
    my heater is still squeaking
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Well I found and eventually got apart the large multiplug near the N/S front fog.... and yucky green corrosion alles uber der platz !
    I've cleaned it out the best I could and had it together/apart a fair few times to try and clean up the contacts, but it's still giving dodgy readings. Next step come next Tesco day will be get hold of a can of electrolube and squirt the hell out of the contacts.
    Incidentally, a thought occurred about possible diagnosis of sensor fault or not:
    Assume the sensor works by changing the resistance in the OAT circuit wire.
    Disconnect the sensor and the display should drop into the -28c range. Mine stayed at about 10.5c which now indicates additional resistance in the wire - so pointing toward possible corroded multiplug contacts.
    Just a thought
    Dec 2011
    Seaham
    WD40 will be good enough as a contact cleaner, it will also act as a dampness guard.
  1. Outside temperature sensor gone mad!
    By devore in forum Electrical & ICE (including SatNav)
    Last Post: 20th August 2013, 16:58
  2. Temperature Sensor?
    By JaceyBoy in forum Engine & Drivetrain
    Last Post: 18th May 2012, 21:52
  3. Outside Temperature Sensor
    By Finty in forum Vectra C / Signum Car Chat
    Last Post: 5th January 2009, 23:35
  4. Outside air temperature sensor
    By Pjuk in forum Vectra C / Signum Car Chat
    Last Post: 30th December 2008, 13:31
  5. outside temperature sensor
    By billyyoung in forum Electrical & ICE (including SatNav)
    Last Post: 23rd March 2008, 17:23
