Results 1 to 10 of 11
Thread: how to disable washer fluid sensor
    Regular Member dcm23251981's Avatar
    Jul 2011
    burnley
    Default how to disable washer fluid sensor
    hi was told that you can fit some wire and earth it to disable washer sensor
    1 where is the fuse to do it
    2 is it straight forward to do . wire in then to earth point is that it ?
    morecambe
    44 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Just short the pins out on the plug mate
    Regular Member peadar's Avatar
    Aug 2007
    in the glens of Antrim N Ireland
    Vehicle : ELITE
    Trim : FULL LEATHER
    Engine : 1.9 CDTI 150 BHP
    Mileage : 87,000
    just fill the water bottle lol
    Regular Member Ziggy's Avatar
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    Why would you want to?
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    or put some tape around the float to make it think the tank it full.
    Jul 2011
    burnley
    sorted it earthed with wire thanks for the advise
    Engine : 1.9 CDTi
    Quote Originally Posted by s_zigmond View Post
    Maybe he has just had check control enabled and doesnt have the sensor fitted.
    Full Member Robsey's Avatar
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    For information -
    MOST vectra's will have the connector for the sensor tied up near to the washer pump in the space in-front of the near-side front wheel arch.
    If you DO have this plug, then simply link the two pins together.
    If you do NOT have this plug, then you will need to find pin 14 in connector number 2 of the under-hood fuse box. You will then need to run a wire from here, to a good clean earth point.
    As mentioned, I assume that he wants the bulb check facility, but cannot be bothered to mess about fitting a fluid level sensor.
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    Or buy the sensor and fit it, it's only a few quid
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    Normal Vx price is about £25 for the sender / switch, and the rubber grommet / seal is about £3
    Although youu can get the senders for less off ebay - but these do not come with the grommet / seal.
    Oh and yes, you will need to drill a big hole in the side of your washer bottle... approx 22mm diameter but I do not know exactly, as it is 12 months since I did the wife's.
  1. Washer Fluid level sensor???
    By Ian S100 in forum Vectra C / Signum Car Chat
    Last Post: 9th February 2016, 00:15
  2. how to disable low washer fluid level
    By mrk in forum Electrical & ICE (including SatNav)
    Last Post: 8th June 2012, 13:54
  3. Washer fluid leaking
    By monty2000 in forum Bodywork & Interior
    Last Post: 3rd February 2012, 11:47
  4. Washer fluid check.
    By blackveccyC in forum Electrical & ICE (including SatNav)
    Last Post: 12th September 2011, 14:07
  5. Which washer fluid?
    By vxvirgin in forum Vectra C / Signum Car Chat
    Last Post: 3rd April 2009, 08:15
vectra c wash fluid sensor location
vectra c washer fluid level
disable fluid sensor
vectra c washing fluid disable
vectra c disable check control
wash fluid level opel vectra
vectra 2005 washer low level when full
vectra check washer fluid
