Results 1 to 10 of 17
Thread: Dash Info screen Broken
    Regular Member Vectra_C_Chris's Avatar
    Perth Western Australia
    Default Dash Info screen Broken
    Hi guys.
    I think after a solid week of 40 Degrees Plus, the screen has just gotten two hot whilst parked, and started to die. Looks like a whole bunch of dead pixels
    Is there anyway to repair this? Or is a new screen required? Electronics and me don't mix, so I'm quite unsure what exactly is the issue.
    Cheers,
    Chris
    Full Member spennny's Avatar
    Blantyre
    I think you could buy the new screen mate , but would prob be easier to buy the whole clock set and have the mileage reset to your current vehicle mileage
    I was thinking the same. Theres actually a GSi being wrecked in Aus (1 in the whole country...) so hopefully they have the whole clock set available.
    Blantyre
    If your stuck and you find one on ebay UK, gimme a shout mate and i could post it to you
    jesus Christ. The guy in Aus wants 198 quid for it!
    The problem with buying from the UK is your clocks show milage, not KM's
    [Ex]Admin Duncan's Avatar
    Well at least it would work in your favour when you came to sell if the tachometer was in miles!
    Sent from my HTC Desire using Tapatalk
    Wondering lonely as a cloud
    26 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    Quote Originally Posted by Vectra_C_Chris View Post
    We have members and a mod based in mainland Europe mate I am sure we could sort something for you We would love 40 degrees here I would settle for 40 degrees F not worried about C
    Engine : 1.9 CDTi
    Have you taken it apart to see how display is attached?
    You might be able to just swap that lcd bit.
    Quote Originally Posted by lee gsi View Post
    No I havent attempted this as I really would have no clue what I'm looking at.
    Full Member Robsey's Avatar
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    These little displays are clipped onto the circuit board, however they are linked via a flexi / foil ribbon which is bonded onto the circuit board.
    You will need someone who is conversant with this panel to successfully replace the little display.
    If you replace the entire instrument panel, then this will need to be Tech 2 programmed to the vehicle, as this contains the IPC module.
  1. In dash Info screen
    By Vectra_C_Chris in forum Electrical & ICE (including SatNav)
    Last Post: 2nd February 2012, 02:02
  2. Info screen help
    By GAV_SRI in forum Electrical & ICE (including SatNav)
    Last Post: 6th December 2010, 23:05
  3. Cd70nav + broken screen.
    By frasedeb in forum Electrical & ICE (including SatNav)
    Last Post: 28th November 2010, 00:04
  4. cd70+broken screen out.
    Last Post: 23rd November 2010, 23:15
  5. cd70- broken screen???
    Last Post: 18th November 2010, 23:06
