Results 1 to 2 of 2
Thread: In dash Info screen
    Regular Member Vectra_C_Chris's Avatar
    Perth Western Australia
    Default In dash Info screen
    Hi guys.
    I think after a solid week of 40 Degrees Plus, the screen has just gotten two hot whilst parked, and started to die. Looks like a whole bunch of dead pixels
    Is there anyway to repair this? Or is a new screen required? Electronics and me don't mix, so I'm quite unsure what exactly is the issue.
    Cheers,
    Chris
    Full Member Robsey's Avatar
    North East Cheshire
    22 Post(s)
    Trim : Energy
    Mileage : 131,000
    These little displays are clipped onto the circuit board, however they are linked via a flexi / foil ribbon which is bonded onto the circuit board.
    You will need someone who is conversant with this panel to successfully replace the little display.
    If you replace the entire instrument panel, then this will need to be Tech 2 programmed to the vehicle, as this contains the IPC module.
  1. Dash Info screen Broken
    By Vectra_C_Chris in forum Electrical & ICE (including SatNav)
    Last Post: 8th May 2012, 18:48
  2. info screen dimming
    By Al 22 dti in forum Electrical & ICE (including SatNav)
    Last Post: 2nd February 2012, 11:54
  3. Info screen help
    By GAV_SRI in forum Electrical & ICE (including SatNav)
    Last Post: 6th December 2010, 23:05
  4. info screen fitment?
    By ronnie63 in forum Electrical & ICE (including SatNav)
    Last Post: 30th April 2009, 08:28
  5. Info screen problem
    By steviemac74 in forum Electrical & ICE (including SatNav)
    Last Post: 12th January 2008, 18:54
