Results 1 to 2 of 2
Thread: EGR Question
    Jun 2011
    Ayrshire
    Default EGR Question
    Hi All,
    Just a question relating to the EGR valve on my vectra c cdti (150)
    Is it possible to just diconnect the plug from the EGR valve as opposed to blanking it off or does this make the car run like a bag of nails?
    Or is it better blanking it off?
    Where exactly do the exhaust gases go if you either disconnect or blank of the EGR?
    Does it have any long term effects on the engine??
    Apologies for all the questions
    Cheers,
    Gaz
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    You can just unplug the EGR and it will still run fine (apart from the spanner light), but if the fault is down to the EGR valve not sealing properly then any running issues would still be evident, blanking is the only way to test for a non-sealing EGR.
    When blanked, the exhaust gasses just carry on down their normal route (out of the exhaust).
    Long term effects, I certainly haven't heard of any on the VX CDTi - alot of people run blanked EGR valves on here
  1. GSI Inner tie rod question.
    By Lee_gsi in forum Suspension, Wheels & Brakes
    Last Post: 9th August 2011, 19:46
  2. question about hid
    By marc vectra sri in forum Electrical & ICE (including SatNav)
    Last Post: 22nd July 2011, 23:15
  3. Vaux-Com / Op-Com question - Screen change question
    Last Post: 16th May 2010, 23:54
  4. Just a question...!
    By Maxim007 in forum Styling
    Last Post: 26th January 2010, 20:12
  5. BSR question
    By soulman in forum Vectra C / Signum Car Chat
    Last Post: 6th October 2007, 22:55
