Results 1 to 10 of 11
Thread: dragging tyre (and the clunk)
    Aug 2010
    whitley bay
    Default dragging tyre (and the clunk)
    Hi guys every now and then I get the clunk assiciated with the strut top bearing when on full lock (lowered on coilover too) and ive just recently noticed that when turning left it feels like the drivers side wheel is scrubbing the road (feels like slipping) I thought this was down to the surface but does it on various surfaces? car tracks straight with no issues there.
    any ideas guys?
    Phil
    Regular Member MrDerv's Avatar
    Nov 2011
    North East (Beamish)
    I'd maybe get the tracking looked at. Is the camber of the wheels ok?
    Aug 2010
    whitley bay
    seems the same both sides - might get it looked at too incase ive had a knock and cant visibly see anything , just with it only dragging on the one side?
    Jun 2009
    South Coast
    8 Post(s)
    Vehicle : Signum & Insignia
    Engine : POS derv
    sounds like something is worn out, maybe a track rod..
    Aug 2010
    whitley bay
    ah that could explain it, if the arm is moving but theres not as much movement at the end that would cause it to drag wouldnt it?
    Jun 2009
    South Coast
    8 Post(s)
    Engine : POS derv
    have you sorted this?
    Regular Member Big Red's Avatar
    May 2011
    Dudley (Cramlington)
    i believe phil ordered the track rod ends and strut top bearings the other day think he could be fitting them this weekend matey
    lincolnshire
    i would suggest checking the bushes on the bottom arms too
    Aug 2010
    whitley bay
    got everything fitted and tracked up this morning - problem seems to have gone (top mount bearings were shot too, track rod ends wernt too bad but changed em anyway seeing as I had the new parts) will report on this in a few weeks
    and on a better note my TA technix coilovers that were coming up to 2 years old were in excellent condition no corrosion or leaks at all just a bit of loose paint on one coil - highly recommended considering theyve been through 2 winters with salt on the roads etc
    Jun 2009
    South Coast
    8 Post(s)
    Engine : POS derv
    Good news, a job worth doing.
  1. clunk
    By matt.d in forum Suspension, Wheels & Brakes
    Last Post: 28th May 2011, 19:12
  2. Big Clunk
    By Ben_ in forum Suspension, Wheels & Brakes
    Last Post: 2nd January 2011, 15:03
  3. Dragging up an old discussion!!
    By Matt&Jemz in forum The 'Off Topic' room
    Last Post: 2nd March 2010, 10:37
  4. Clunk..........
    By david.aka.judas in forum Vectra C / Signum Car Chat
    Last Post: 2nd October 2009, 21:53
  5. Clunk!
    By B19CBB in forum Suspension, Wheels & Brakes
    Last Post: 21st January 2008, 18:30
