Thread: Cant post this in ICE section?.
    Regular Member Ben_'s Avatar
    Audiville, WM
    Default Cant post this in ICE section?.
    After 3 aftermarket stereo I'm thinking of going back to standard look and installing a parrot at later date.
    So question is, will stereo with code work straight off or doi need to make sure it's been unpaired? Cars a 03 preface with TID, planning to install GID if i get chance.
    Would new stereo need to be out of preface or would facelift be ok? Had a CDR2005 previously I think.
    All advice appreciated people, and if you've got an old stereo lying around gathering dust let me know.
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    You would need Prefacelift.
    if you have OEM stereo, you just need to keep at save it (code is on the carpass)
    Audiville, WM
    Halfords blew up my previous stereo!!
    Engine : 2.2 Direct
    Quote Originally Posted by Ben_ View Post
    Then you have to make sure you get the code with the new used radio.
    Audiville, WM
    Would facelift with screen not work?? Or is a canbus issue
    Engine : 2.2 Direct
    Different wiring and other bits.
    Audiville, WM
    ok so CDR2005 is my only option then?? also if I want to change TID to GID is this going to cause problems with original headunit as they won't be paired??
    Engine : 2.2 Direct
    or CCR2006 are the easy things... you can do other.. but will be more work.
    No no problem with the GID upgrade.
  1. Can't post in ebay section?
    By damers2000 in forum Vectra C / Signum Car Chat
    Last Post: 22nd January 2012, 21:13
