Thread: friends broken corrolla
    Nov 2009
    N/A
    Default friends broken corrolla
    Not actually my car, but I'm hoping someone may be able to shed some light. I have a friend with a 1.4 2000 reg Toyota Corolla (engine 4ZZ-FE)
    The other day she started it, it ran for a few seconds, then cut out! Read the DTC's and it pinged up "P0170 (Fuel trim (FT), bank 1 - Malfunction". It turns over ok, occasionally sounds though it tries to fire, but won't. when cranked you can smell a faint trace of petrol at the exhaust.
    I cleared the fault code, but it still won't start and the code has not re-appeared.
    I'm not familiar with these engines, any ideas what should I be checking for/looking to fix or replace?
    Dec 2011
    Seaham
    I would check the fuel filter, fuel pump first to se if you are getting fuel to the injection system.
    Regular Member dannyjpuk's Avatar
    Jan 2010
    northumberland
    ilmao i thought that said motorola (mobile) lol
    north east
    could be a immobiliser fault find otu where its located ( probably steering wheel area) and clean the contacts with WD40.
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Need to check your getting a spark. Could be coil pack
    Nov 2009
    N/A
    Quote Originally Posted by Critch View Post
    It doesnt have a single coil pack, rather separate coils on each plug, so I find it unlikely that they've ALL failed at exactly the same time!
    Dec 2011
    Seaham
    Try cranking it over, then take a plug out, see if its wet? If not, probably petrol fault?
  1. Broken banks of river = broken vectra...
    By andrew e in forum Vectra C / Signum Car Chat
    Last Post: 23rd May 2012, 20:48
  2. I need your help my friends
    By Passos78 in forum General Chat
    Last Post: 4th October 2010, 20:55
  3. I need your help my friends
    By Passos78 in forum The 'Off Topic' room
    Last Post: 4th October 2010, 07:51
  4. a friends car
    By lee_eardley in forum Gallery
    Last Post: 18th October 2007, 15:43
