Thread: Ticking noise from engine??
    Sussex
    confused Ticking noise from engine??
    Hi all I hope you can help please, my Vectra is causing problems again!!
    It's a 55 plate 1.9 cdti 150 bhp, and on the way home tonight it started making a sort of squealing noise from the engine? It's an odd sort of noise and I can only liken it to when you used to have a cassette deck and when the tape ran out it would make a squeal type noise, that sort of thing but also whirring / high pitch noise too. No other symptoms, seemed ok to be driving, no over temperature reading (even tho it never really gets above 1/4 anyway) not driving particularly badly, no worse than normal?
    The only thing my OH found was when he turned the engine off and then back on, when the key was on the first click over ie lights on dash / waiting for the glow plugs to go out, that's when the ticka-ticka was at its worst, with the noise coming from the top left ish of the engine bay if you're standing at the front of the car.
    I'd really appreciate if anyone can help, it's going to our mechanic tomorrow and having the diagnostic plug in but I don't know if it will show anything as there are no faults / lights on the dash?! This may be the straw that broke the camels back, had so many problems with it I don't know what to do any more!!!
    Thank you so much all in advance...
    morecambe
    44 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Squeaky aux belt mate nothin to worrie about It's also cheap to change
    Regular Member the_riddler's Avatar
    Oct 2010
    Carshalton
    Quote Originally Posted by paulvectrac View Post
    What he said, also try driving with nothing eletric switched on. Then turn on lights, heater, heated screen and see if it gets worse. This should help you confirm the squeeky aux belt!!
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Quote Originally Posted by Gracey View Post
    If it was at it's worst when the engine is not running, it can't be the belt.
    Probably either air solenoids switching / clicking or a pump
    Cheshire
    Power steering pump?
  1. Ticking noise from rear of engine
    By steveyd83 in forum Engine & Drivetrain
    Last Post: 20th September 2012, 21:57
  2. Ticking noise v6 cdti engine
    By Critch in forum Diesel Engine related
    Last Post: 9th June 2011, 23:49
  3. ticking noise from engine
    By johnny ni in forum Engine & Drivetrain
    Last Post: 2nd December 2010, 23:16
  4. Vectra C 1.8 SRI engine ticking noise
    By peternotails in forum Engine & Drivetrain
    Last Post: 1st October 2009, 20:25
  5. Ticking noise from engine... more so near the injectors
    By JonR in forum Engine & Drivetrain
    Last Post: 28th January 2008, 20:54
