Thread: Need help with blower/fan
    Oct 2010
    Poland
    Default Need help with blower/fan
    Hello,
    I have a Vec C 1,9 CDTI and have a strange problem with ventilation system. The problem occurs 3 days ago before it everything was fine, if I set gear to 7 position (the strongest) it only blew a little from airducts. My blower motor is working on every gear 1-7 (I can hear it changes its RPM). It doesn't matter if i turn A/C on or off nothing changes, it doesn't matter if change in options if a/c should blow weak/normal/strong. The directions are working (windshield, general, legs) but also blowing is very weak even though it is set to 7. cabin filter is knew i also changes blower motor to another one nothing change. Could you please help me? computer dont show any errors.
    Dec 2011
    Seaham
    Sounds like the airflow flaps have stuck.
    Oct 2010
    Poland
    do you have a schema where i can find them?
    Oct 2010
    Poland
    today i have checked flaps that are visible behind glove box (for stering a passanger flow, inside circulation) are working any other ideas?
  1. Blower
    By nokiaman1978 in forum Bodywork & Interior
    Last Post: 23rd April 2012, 22:43
  2. No hot air out of blower
    By dannycturbo in forum Vectra C / Signum Troubleshooting
    Last Post: 28th January 2012, 10:33
  3. Blower gsi 3.2
    By grabcol01 in forum Electrical & ICE (including SatNav)
    Last Post: 20th September 2011, 21:55
  4. blower
    By bakery in forum Electrical & ICE (including SatNav)
    Last Post: 27th December 2010, 15:18
  5. Not hot air thru the blower!
    By jimmytarnat in forum Vectra C / Signum Car Chat
    Last Post: 30th April 2009, 19:15
