Results 1 to 10 of 14
Thread: wiring help please
    Regular Member tommythomson12's Avatar
    Mar 2011
    Rochdale - North-West
    Default wiring help please
    Right i hope someone on here can help me. My other half as a megane (i know) with a problem with the windows (drivers) easy way to say it is it as two wires going into the motor for it to go up and down. But it will only go up, thats until you change the wires over then it will go down. I want to know if i get buy something i could put the wires in first before it goes to the motor so i can put it in the door storage part then when i want it to go up i can press the control and it goes up, but then when i want it to go down i can press a switch and somehow it changes the wires over and lets the window go down. I hope you lot know what i'm talking about. Just so i don't need to have wires in the car that i have to keep changing over everytime i want it to go down.
    Dec 2011
    Seaham
    The only way I can think of would be to knock something up with relays as it will also have to handle the power.
    Might be easier, just to get the problem fixed as it sounds like it may be the switch or a relay that reverses the power/earth.
    Mar 2011
    Cheers the switch is ok has i have tried three now and it still does the same. When we got the car the guy before had cut the wires and put two new wires to one side and two to the other then put them though the door card into the car with plugs on the end so he could swap them over to make it go up and down. Just thought there might be something out there, were i could do the same as the last guy but instead of having to change the wires over i could just press a button and somehow it would change the wires over for me
    Dec 2011
    Seaham
    Why dont you compare the wiring with the other side? Like I said, it may be as simple as needind a new relay/controller?
    Mar 2011
    I have tried that but on these cars the relays are stuck in and won't come out. thats meganes for you bob.
    Dec 2011
    Seaham
    Do you mean glued in? Or do they have tabs on them that need to be pushed in to release the relay? Sometimes, you can only release a relay be turning the panel upside down.
    Mar 2011
    I think they are soldered in mate
    Dec 2011
    Seaham
    Blimey! I bet the dealers charge a fortune to change them!
    Mar 2011
    thats the thing mate, what could i looked for to do what i want to do. with the switch
    Dec 2011
    Seaham
    You simply want something that swops the polarity of the wires, depending on which way the switch is.
    http://www.ebay.co.uk/itm/Power-Wind...item5d25c6e354
    This may do it?
  1. Tow Bar Wiring Help Please
    By countduckula55 in forum Electrical & ICE (including SatNav)
    Last Post: 23rd July 2012, 10:55
  2. Wiring help please?
    By Danwells72 in forum Electrical & ICE (including SatNav)
    Last Post: 13th March 2010, 23:13
  3. I need help with wiring.
    By gibbon7000 in forum Electrical & ICE (including SatNav)
    Last Post: 8th June 2009, 00:41
  4. Sub Amp Wiring kit
    By nick-v2.2 in forum Electrical & ICE (including SatNav)
    Last Post: 9th April 2009, 22:32
  5. Tow wiring
    By amiddleton in forum Electrical & ICE (including SatNav)
    Last Post: 14th May 2008, 07:57
