Results 1 to 10 of 13
Thread: 2.2 SRI Random Cut Outs
    Apr 2011
    uk
    Default 2.2 SRI Random Cut Outs
    Hello, need a little help
    I have got an 03 2.2 sri direct petrol with 80000 miles and it likes to cut out in low revs and sitting in traffic. The car like to cut out and put the eml light on, it will not start straight away after this happens. When turning the key after it has cut out you get nothing, doesn’t even try to start. Leaving it for about 2-5 mins it will start and run with the eml light on.
    Drove about 160 miles trip the other day without a problem, got 5miles from home and road works had me in traffic for 5mins and the car just cut all power. Got it started again but it cut out 2 mins after while driving, lost all power, tired dropping it a few gears to give it a kick in the a** but it just died.
    I have found the car a bit hesitant and lumpy sitting in low revs, below 2500rpm. The car runs fine above 2500rpm and is nippy with no hesitation, cant drive flat out everywhere.
    I have read a few posts of faulty fuel pumps and faulty EGR valves .Can any one help me on this 1 and point me in the right direction
    Mar 2009
    morecambe
    54 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    If it is a siggy direct it will be the hpfp or the fpr if it's a Vectra I don't think they was a direct till 2004 mate
    Apr 2011
    uk
    could well be, all i know is its a 03 2.2sri with the z22se engine. read abit about the hpfr going to have to look in to it.
    cheers
    Mar 2009
    morecambe
    54 Post(s)
    Vehicle : vectra
    Trim : vxr
    Yours is not a direct Matr just a standard 2.2 the 2.2s are less powered than the directs
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Mileage : 137000
    Quote Originally Posted by paulvectrac View Post
    Or Siggys were fitted with direct cos they have a fat arse so are naturally slower.
    Mar 2009
    morecambe
    54 Post(s)
    Vehicle : vectra
    Trim : vxr
    Alright steve let's not get personall ya girl lmao
    Vehicle : 9-3 Wagon
    Mileage : 137000
    Lol
    Sent from my Sony Ericsson Xperia using Tapatalk
    Vehicle : 9-3 Wagon
    Mileage : 137000
    Nreid, the EGR would have to be stuck open to cause any poor running, but im not sure if it would cause it to stall? A mate of mine had a faulty O2 sensor on his 2.2 and it caused the same problems as your having.
    I see you've posted over on Z22, one of the chaps over there should be able to sort you out m8.
    Apr 2011
    uk
    yea put one on z22 see if i can find out what this is. had it out 2day and when i was pushing it over a ton the eml light started flashing? didnt effect the car or preformance
    Vehicle : 9-3 Wagon
    Mileage : 137000
    [ame="http://www.youtube.com/watch?v=JeR-qGjAN4g&list=UUg2kZGw3kXkUKKn2mOha1bg&index=6&feat ure=plcp"]THIS[/ame] is how you can check the EGR is working and moving properly.
    It could even be a timing fault, and in that case you dont want to be pushing it m8.
  1. obdll pin outs
    By Al 22 dti in forum Electrical & ICE (including SatNav)
    Last Post: 27th January 2012, 11:47
  2. Scvs. . . . Who knows the ins and outs??
    By s2yob in forum Y & Z30DT Specific
    Last Post: 9th November 2011, 21:03
  3. RCA outs on NCDC2015?
    By elite3.2 in forum Electrical & ICE (including SatNav)
    Last Post: 1st January 2010, 19:08
  4. Cd70 Pre Outs
    By MRLUBBERLUBBER in forum Electrical & ICE (including SatNav)
    Last Post: 26th October 2008, 01:45
